Optimizing Friction for Moving Sand: What Angle Should the Cable Be?
  • Thread starter Thread starter king_naeem
    Friction
The discussion revolves around optimizing the angle of a cable used to pull a box of sand across a floor, considering the tension limit and the coefficient of static friction. Participants are exploring how to maximize the weight of the sand that can be pulled without exceeding the tension limit of 1100 N.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are discussing the equations of motion involved, particularly focusing on the relationship between tension, angle, normal force, and weight. There are attempts to rearrange equations to express weight as a function of the angle and to understand the implications of the angle on the normal force.
Some participants have provided guidance on rearranging equations and expressing variables in terms of others. There is a suggestion that the angle for maximum weight could be related to the arctangent of the coefficient of static friction. Multiple interpretations of the equations and their implications are being explored.
Participants are questioning the assumptions regarding the relationship between the normal force and gravitational force due to the angle of the applied tension. There is also a mention of a specific numerical limit for tension and the coefficient of static friction that must be considered in the analysis.
king_naeem
Question: An initially stationary box of sand is to be pulled across a floor by means of a cable in which the tension should not exceed 1100 N. The coefficient of static friction between the box and the floor is 0.35.
a) what should be the angle between the cable and the horizontal in order to pull the greatest possible amount of sand?
b)What is the weight of the sand and box in that situation?
My solution that gives me the 'incorrect' answer:
Eqn 1--> Tcos(theta) - u(static coefficient)F(normal)=0
Equation 2--> Force Normal + tsin(theta) - mg=0
I can solve for the force normal to be equal to = mg/1.35
For there i assumed that the angle should be 45 degrees (i know..wrong assumption) but have no clue what to do next...
any help would be appreciated
These two equations are fine. Rearrange them to show the weight (mg) as a function of the angle. Find the angle that maximizes the weight.
how would i rearrange the first equation to get it interms of mg?
b/c the i have
force normal does not equal the force of gravity because the force applied on the string is at an angle so i can't just say 'force of gravity=force normal' can i? :confused: unless I'm wrong yet again...ahh!
okay...is this right so far
i get by combining and rearranging the following new equation:
Cos (theta) + Sin(theta)= 0.003121363m
where m is the mass of the object...what should i do next?
b/c the i have
1.I should like to congratulate DocAl for his 3000 posts.
2.From the first equation express N (the normal force of pressing) in terms of µ,T and theta.Plug it in the second equation and obtain the function m=m(µ,theta,T,g).Since g is constant,for the max of m you must have max tension T (1100 N) and a special angle which is found by the condition of maximum imposed to m seen as a function of theta (considering T as a parameter).My guess is that angle should be arctan (µ).Then insert all numerical data and get the maximized mass.
I believe it's all clear now.
Thanks, Daniel!
2... My guess is that angle should be arctan (µ).
Good answer (and good "guess"). :wink:
9K
