Dc motor load increase as rpm increases?
The discussion centers on the relationship between RPM and current in a DC motor connected to a diaphragm pump. As voltage increases, both RPM and current (torque) rise, contradicting the expectation that increased RPM would lead to higher back EMF and lower current. The mechanical load on the pump increases with RPM, necessitating higher torque to maintain performance. Consequently, to achieve the same RPM with a different motor, it must provide equivalent torque, regardless of the motor type.
  • Understanding of DC motor operation and characteristics
  • Knowledge of back EMF principles in electric motors
  • Familiarity with torque and its relationship to mechanical load
  • Basic concepts of pump mechanics and performance metrics
  • Research the principles of back EMF in DC motors
  • Explore torque calculations for different motor types
  • Investigate the impact of mechanical load on motor performance
  • Learn about the efficiency of diaphragm pumps at varying RPMs
Engineers, motor control specialists, and anyone involved in the design or optimization of DC motor-driven systems, particularly in applications involving pumps.
mabuchi
I have a dc motor geared to a diaphragm pump, and all hardware are unchanged.
As i increase the supplied voltage, rpm increases, but so does the current (torque).
I thought rpm increase would lead to higher back emf, and thus lowers the current. So would the only reason for my increased current be that the mechanical load increases as rpm increases?
Yes, the mechanical load doesn't care about electrons: if the rpm increases on a pump, the pressure and power increase too - by square and cube funtions, respectively.
so if i were to use a different motor (other pump components unchanged) to achieve the same rpm as the current motor, does it need to have the same torque?
In other words, are rpm and torque tie together, so that you would need the same torque to achieve the same rpm for any motor (other pump components unchanged)?
  • · Replies 16 ·
  • · Replies 43 ·
