New Reply
Uniform Solid Sphere
Share Thread Thread Tools
Dec2-11, 05:54 PM   #1
Find the moment of inertia of a uniform solid sphere of mass,m and radius,a about an axis through its centre.
I have tried to solve it but I get the different answer, I don't know where I have done mistake. Please! check and correct my solution below:-
Consider a volume element, dv of the sphere; this has mass,mdv/(4/3)∏a^3.
Then
I = ∫(mdv/(4/3)∏a^3)r^2
Where r is the distance of the volume element, dv from the axis, and
I is the moment of inertia
I = m/(4/3)∏a^3∫r^2dv
We know, the volume of the sphere,v is:
v = (4/3)∏r^3
dv = 4∏r^2dr
Thus,
I = 3m/(4/3)∏a^3∫r^2(4∏r^2)dr
= 3m/a^3∫r^4dr under limit [0,a]
= 3m/a^3[r^5/5] under [o,a]
Hence,
I = (3/5)ma^2 --------------WRONG!!!
The correct answer is: I = (2/5)mr^2
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Dec2-11, 06:06 PM   #2
Recognitions:
For starters you seem to mixing r and a.
Dec2-11, 06:25 PM   #3
Mentor
Quote by Mirumbe View Post
Here r is the distance to the axis.
v = (4/3)∏r^3
dv = 4∏r^2dr
Here r is the distance to the center.
Dec3-11, 03:06 AM   #4
My intention was to find the volume element, dv of the sphere about the axis. But, since the axis was through its centre that's why I said
v = (4/3)∏r^3
Then, after differentiating w.r.t variable, I got the volume element, dv
dv = 4∏r^2dr
So, if I am wrong here,what should I do, so as to get the volume element,dv?
Dec3-11, 04:34 AM   #5
Recognitions:
I'd use cylinder coordinates [itex]\rho,\varphi,z[/itex]. The sphere is given by [itex]\rho \in [0,R][/itex], [itex]\varphi \in [0,2 \pi[[/itex], and [itex]z \in [-\sqrt{R^2-\rho^2},+\sqrt{R^2-\rho^2}[/itex]. Let [itex]n=\text{\const}[/itex] be the mass density. Then the moment of inertia is
[tex]\Theta=n \int_0^{R} \mathrm{d} \rho \int_0^{2 \pi} \mathrm{d} \varphi \int_{-\sqrt{R^2-\rho^2}}^{\sqrt{R^2-\rho^2}} \mathrm{d} z \; \rho^3.
[/tex]
There one factor of [itex]\rho[/itex] comes from the volume element [itex]\mathrm{d}^3 x=\rho \mathrm{d} \rho \mathrm{d} \varphi \mathrm{d} z[/itex].
The integrals over [itex]z[/itex] and [itex]\varphi[/itex] are trivial. You find
[tex]\Theta=4 \pi n \int_0^R \mathrm{d} \rho \; \rho^3 \sqrt{R-\rho^2}.[/tex]
This remaining integral becomes
[tex]\Theta=\frac{8 \Pi}{15} n R^5 = \frac{8 \pi}{15} \frac{3m}{4 \pi R^3} R^5=\frac{2}{5} m R^2.[/tex]
Dec3-11, 05:03 AM   #6
Thanks Vanhee71 for your solution although it is the new idea to me.
Dec3-11, 05:09 AM   #7
Mentor
Unfortunately, vanhees71 just did the problem for you which deprives you of figuring it out on your own.
The key point is to choose a volume element for which you can easily write down the moment of inertia. You chose spherical shells. (And in the process, mixed up the radius of those shells with the distance of a mass element to the axis of rotation.) You could do the problem that way, but you'd have to know the moment of inertia of a spherical shell. The better way is use cylindrical shells, which are easy. What's the moment of inertia of a cylindrical shell?
Dec3-11, 01:41 PM   #8
The moment of inertia of the Cylindrical shell is:
I = MR^2
New Reply
Thread Tools
Similar Threads for: Uniform Solid Sphere
Thread Forum Replies
electric field, solid sphere inside hollow sphere Introductory Physics Homework 1
Moment of Inertia of a solid uniform sphere Classical Physics 2
Rotational Energy, 2 blocks and a pulley (solid uniform sphere) Introductory Physics Homework 0
Moment of inertia of a uniform solid sphere Calculus & Beyond Homework 2
Moment of inertia of a uniform solid sphere Introductory Physics Homework 7
