What does this symbol mean (Countour integration over a boundary)?
In summary, the symbol \oint_{{\partial}\omega}\omega refers to a contour integral with a boundary represented by {\partial}\omega. The differential at the end of it is not necessary as \omega is already a differential. Depending on the context, the boundary {\partial}\omega can represent a surface or a closed curve, and can be evaluated using Green's theorem, Gauss's theorem, or Stokes' theorem. These theorems show identities between an integral over an area, and an integral over the boundary of that area. The exterior derivative of a differential-form ω is used to calculate the integral, and can be done using a pullback chart.
joebohr
57
I keep seeing this symbol, something like [itex]\oint[/itex][itex]_{{\partial}\omega}[/itex][itex]\omega[/itex], I know it is a contour integral and read that [itex]{\partial}\omega[/itex] is called a boundary, but I don't know what it means or why there isn't a differential at the end of it. Can someone please answer these questions and explain how to evaluate it? Thanks in advance.
Well, you would not see what you have given because if [itex]\omega[/itex] is appropriate in one of those uses, it is inappropriate in the other. You might well see [itex]\int_{\partial S} \omega[/itex]. Here, S is a set and [itex]\partial S[/itex] is the boundary of that set. There is no "dx" because [itex]\omega[/itex] is already a differential possibly not in terms of "x".
If that is a path integral in three dimensional Euclidean space, it might be [itex]\int_{\partial S} f(x, y,z)dx+ g(x,y,z)dy+ h(x,y,z)dz[/itex] where we are taking the integral over the boundary of some two dimensional set S in R3 and the differential to be integrated is [itex]\omega= f(x,y,z)dx+ g(x,y,z)dy+ h(x,y,z)dz[/itex].
On the other hand, if S is a three-dimensional subset of R3, it boundary, [itex]\partial S[/itex] would be a surface and an integral on it would be [itex]\int_{\partial S} f(x,y,z)dxdy+ g(x,y,z)dydz+ h(x,y,z)dxdz[/itex]. Here the differential to be integrated is [itex]\omega= f(x,y,z)dxdy+ g(x,y,z)dydz+ h(x,y,z)dxdz[/itex].
This clears up most of my questions, but what does the boundary mean? Also, how do I know what s,ω, and [itex]\partial S[/itex] are; would they be given to me in a real problem? If I knew that [itex]\partial S[/itex] was a surface, path, or contour, then could I just replace it with another letter (say L) and integrate accordingly, and would I need to use Stokes' theorem, kelvin-stokes theorem, or the divergence theorem to evaluate it? How would I go about doing this? Basically, what I'm asking is, if S is a path or surface, then how would integrating over [itex]\partial S[/itex] be different than integration over S? Sorry I am asking so many questions but I can't seem to find anything that defines this in detail.
Suppose S is a circle disk.
Integrating over S means integrating over the surface of the disk (surface integral).
Integrating over ∂S means integrating over the perimeter of the circle (contour integral).
Note that ∂S is always closed (a closed curve in this case), whereas S is not closed.Now suppose S is a sphere volume.
Can you think up what ∂S is?And yes, in a real problem you would have more information about all your stuff.
∂S would be the volume of the surface area (simply the surface area of a sphere). But how would I evaluate an integral over ∂S? Would I have to convert it to an integral over S? If so, how would I go about doing this (I think I read on wikipedia that I can use stokes theorem by taking the exterior derivative, which is just the directional derivative in Euclidean Space, and integrating over S)?
Yup.
An integral over a curve is done like this:
http://en.wikipedia.org/wiki/Line_integral#Line_integral_of_a_scalar_field
There are 2 major theorems about this.
Gauss's theorem and Stokes theorem (which is the same as Green's theorem except that Green is for 2 dimensions).
They show identities between an integral over an area, and an integral over the boundary of that area.
Sometimes it is easier to apply one of those theorems to get what you want, but the integrals are properly defined without using them.
I like Serena said:
Yup.
Thanks, I know how to evaluate a line integral, but didn't realize that an integral over a boundary was just a line integral.
I'm pretty familiar with using Green's, Gauss', and the Curl Theorem (which is also applicable in this case unless I'm mistaken), but how would I apply Stokes' theorem? Would I just have to take the exterior derivative of the differential ω? If so, what does the directional derivative of a differential look like?
Now that I think about it, I probably should have put this in a differential geometry forum instead.
You can find your generalized form here:
http://en.wikipedia.org/wiki/Stokes'_theorem#General_formulation
[tex]\int_\Omega \textrm{ d}\omega = \oint_{\partial \Omega} \omega[/tex]
ω is defined here as an (n-1)-differential-form (generalization of a line integral).
dω is defined as the exterior derivative of ω (generalization of a surface integral of the curl).
Note that the surface Ω uses a different symbol and indeed is different from the differential-form ω.And how would you calculate one or the other?
Well, typically by using a pullback chart φ:Ω→ℝn:
[tex]\int_\Omega \alpha = \int_{\phi(\Omega)} (\phi^{-1})^* ~ \alpha[/tex]
This matches of course a line integral, or a surface integral.
So would I be correct in saying
[itex]\oint_{\partial \Omega} \omega[/itex]=[itex]\int_\Omega dω = \int_{\phi(\Omega)} (\psi)* d \omega[/itex]= [itex] \int_{\phi} d (\psi* \omega)[/itex]
Where [itex]\phi[/itex] is the function that maps the surface Ω to ℝ^n (pullback) where ω is an n-form and ψ is the inverse of [itex]\phi[/itex] that maps ℝ^n to Ω (pushforward)? Also, d is the directional derivative, which I now have to take of the product of a function (ψ) and the n-form ω. How would I take the directional derivative of this product? Would the next step be using Green's/Stokes theorem to convert the line integral into definite integrals based off of the extrema of [itex]\phi[/itex] in ℝ^n?
Can someone move this to the differential geometry forum, or is there some way for me to do it myself?
1. What is contour integration?
Contour integration is a mathematical technique used to evaluate integrals along a path in the complex plane. It involves breaking down a complex function into smaller parts and then integrating along a specific path in the complex plane.
2. What is the purpose of contour integration?
The purpose of contour integration is to simplify the evaluation of complex integrals by using the properties of complex numbers and the Cauchy-Riemann equations. It allows for the evaluation of integrals that may be difficult or impossible to solve using traditional integration methods.
3. What does it mean to integrate over a boundary?
Integrating over a boundary means evaluating an integral along a specific path or boundary in the complex plane. This is done by breaking down the integral into smaller parts and integrating along each segment of the boundary.
4. How is contour integration used in science?
Contour integration is used in various fields of science, such as physics, engineering, and mathematics. It is particularly useful in solving problems involving complex variables, such as fluid dynamics, electromagnetism, and quantum mechanics.
5. Are there any limitations to contour integration?
While contour integration is a powerful tool, it is not always applicable to every integral. In some cases, the contours may be too complex to evaluate, or the function being integrated may have singularities that make it difficult to apply contour integration. Additionally, the choice of contour can greatly affect the accuracy of the integral evaluation.
  • Quantum Physics
14K
