What is the line integral for the given line segments and parametric equations?
The discussion revolves around finding the line integral of the expression ∫ x+yz dx + 2x dy + xyz dz over specified line segments in three-dimensional space. The line segments connect the points (1,0,1) to (2,3,1) and (2,3,1) to (2,5,2).
  • Mixed
  • Participants explore different parametric equations for the line segments, with some suggesting alternative parameterizations and questioning the integration limits used by others.
  • There are attempts to verify calculations and clarify misunderstandings regarding the integration process and the resulting values.
  • Some participants express confusion about the integration limits and the implications of the chosen parametric forms on the results.
The discussion is ongoing, with participants providing insights into their calculations and questioning each other's approaches. There is a recognition of potential errors in the original poster's calculations, and some participants are attempting to clarify the correct integration process without reaching a consensus on the final answer.
Participants note discrepancies in the calculated results and the expected correct answer, indicating a need for further exploration of the integral setup and assumptions made during the integration process.
maogden
Find the line integral of ∫ x+yz dx + 2x dy + xyz dz
C consists of line segments from (1,0,1) to (2,3,1) and from (2,3,1) to (2,5,2).
r=(1-t)<r0> + t<r1> 0<t<1
I split up the two line segments into C1 and C2.
For C1 I got the parametric equation of x(t)=1+t, y(t)=3t, z(t)=1
I plugged this into the original equation also using dx=dt, dy=3dt, dz=0
This gave me the answer C1=13.
I then found the parametric equations of C2 to be x(t)=2, y(t)=3-2t, z(t)=1-t.
I plugged these into the equations again with their derivatives and got the answer to be -22/3.
I added C1 and C2 and got 17/3 as my answer.
The correct answer should be 97/3.
On the first, if I let:
x=1+t
y=3t
z=1
I get 12.
On the second, how about let
x=2
y=3+2t
z=1+t
If you had shown how you got this, we might have been able to point out a mistake. As it is, we, like jackmell, can only say that your first integral is wrong.
Okay, when t= 0, (x, y, z)= (2, 3, 1) and when t= -1, (x, y, z)= (2, 5, 2). Did you then integrate from 0 to -1?
Sorry I didn't explain my work. I integrated both C1 and C2 from 0 to 1.. why are you integrating it from -1 to 0?
And here's the rest of my work,
C1:
r=(1-t)<1,0,1> + t<2,3,1>
r=<1+t,3t,1>
(from 0 to 1)∫ (1+4t) (1)dt +
(from 0 to 1)∫ (2) (1+t) (3) dt +
(from 0 to 1)∫ (1+t)(3t)(1)(0) dt
[2t^2+t](0 to 1) +
6[t+(t2/2)](0 to 1) +
[t](0 to 1)
(2 + 1) + (6 + 3) + 1 = 13
C2:
r=(1-t)<2,3,1> + t<2,5,2>
r=<2,3-2t,1-t>
(from 0 to 1)∫ 2+(3+2t)(1-t)(0)dt +
(from 0 to 1)∫ 4(-2)dt +
(from 0 to 1)∫ (2)(3-2t)(1-t)(-1) dt
2[t](0 to 1) +
-8[t](0 to 1) +
-2[3t - (5/2)*t2 + (2/3)*t3](0 to 1)
adding these up i got (-19/3) when I redid the problem again.
so C1 + C2 = (20/3)
C1:
r=<1+t,3t,1>
[2t^2+t](0 to 1) +
[t](0 to 1)
Ok, that third one should be zero because z=1 which means dz=0 right? There you go. Got 36/3 of them.
C2:
r=<2,3-2t,1-t>
2[t](0 to 1) +
-8[t](0 to 1) +
so C1 + C2 = (20/3)
[/quote]
Now that second one you have:
[tex]\mathop\int\limits_{(2,3,2)}^{(2,5,2)} (x+yz)dx+2xdy+xyzdz[/tex]
Ok, if I let:
x=2
y=3+2t
z=1+t
then I need to let t go from 0 to 1 so it's
[tex]\int_0^1 (x+yz)dx+2xdy+xyzdz,\quad x(t)=2, y(t)=3+2t, z(t)=1+t[/tex]
you can do that I bet.
I'm not. I asked if you did because your parametric equations, x(t)=2, y(t)=3-2t, z(t)=1-t, give x(0)= 2, y(0)= 3, z(0)= 1, the first point, and x(-1)= 2, y(-1)= 5, z(-1)= 2, the second point.
If you integrate from 0 to 1 then, because x(1)= 2, y(1)= 3- 2= 1, z(1)= 1- 1= 0, you are integrating from (2, 3, 1) to (2, 1, 0) which is not what you wanted to do.
Ok I think I understand..
So what you're saying is...
[itex]0,-1\int[/itex]
(from 0 to -1)∫ (2 + (3-2t)(1+2t))(0)dt +
(from 0 to -1)∫ (2(2t))(3)dt +
(from 0 to -1)∫ (2)(3-2t)(2)dt
simplified:
4 * (from 0 to -1)∫ -4t^2 + 4t + 1 dt
4[(-4t^3)/3 + 2t^2 + t] dt <== from 0 to -1
4(4/3 + 2 - 1 - (0 + 0 + 0)) = 28/3
but,
28/3 + 13 ≠ 97/3
