SR, Inertial frames, Movement, Testing
The discussion revolves around the concept of inertial frames in the context of Special Relativity (SR), exploring their properties, implications for the laws of physics, and methods to test these principles, particularly regarding the speed of light. Participants examine both theoretical and experimental aspects, including classical experiments like the Michelson-Morley experiment.
  • Some participants propose that the laws of physics should hold the same in all inertial frames, emphasizing that inertial frames involve objects moving relative to each other at constant speeds.
  • There is a suggestion that dropping a ball in an inertial frame should yield the same results in another inertial frame, as both frames are not accelerating.
  • One participant presents a scenario involving a car moving at a constant speed and a baseball being thrown, questioning how observers in different inertial frames would measure the speed of the ball.
  • Another participant mentions the Michelson-Morley experiment as a classic test demonstrating that the speed of light is the same in all inertial frames, while also noting that there have been many subsequent tests.
  • Some participants discuss the implications of acceleration, questioning whether the same laws apply if two inertial frames are accelerating at the same speed relative to each other.
  • There is a clarification that if one frame is accelerating relative to another, it cannot be considered an inertial frame, and thus the laws of physics will not take "standard form" in the accelerated frame.
  • One participant expresses a preference for defining inertial frames in terms of the laws of physics taking "standard form," rather than simply as "nonaccelerating."
Participants express differing views on the implications of acceleration in inertial frames and the definitions of inertial frames themselves. There is no consensus on how to best characterize these concepts or the conditions under which the laws of physics apply.
Some discussions involve assumptions about relative motion and acceleration that may not be fully articulated, leading to potential ambiguities in the definitions of inertial frames.
goodabouthood
I wanted to understand something about Inertial frames especially as they are talked about in SR.
It appears that the laws of physics should hold the same in them.
Now I understand that inertial frames only involve things moving relative to each other and moving in constant speed so you can never really discern which one is moving.
Is this a simple test to verify this? If you drop a ball down straight it will hit directly below it, so this should happen in another inertial frame of reference. Both FOR would not be accelerating.
Another way of thinking here is there is a person stationary on the ground and a car moving at a constant 50mph relative to him. He Throws a baseball in his car at 5 mph. Now he should read that the ball is going 5mph but the guy on the ground should read 55mph. Correct?
Now how do you test this same principle for light in inertial frames? How do you test the for the person on the ground and the guy in the car measure the same speed for light?
The classic experiments are the Michaelson-Morley and Fizeau. I can't think of any simple home experiment.
Things in an inertial frame can be accelerating. What cannot be accelerating is one inertial frame relative to another inertial frame. As PatrickPowers says, a classic test that the speed of light is the same in all inertial frames was the Michelson-Morley experiment. There have been many other tests since then.
What if they were both accelerating at the same speed? Would the same laws apply for both of them?
What are they accelerating relative to?
Could I say each other?
Any frame accelerating relative to an inertial frame will definitely not be an inertial frame, so if one of them is an inertial frame, the other cannot be, and the laws of physics will not take "standard form" in the accelerated frame.
I don't find it helpful to think of the primary definition of an inertial frame as "nonaccelerating", since I'd have to say "nonaccelerating relative to an inertial" frame which is consistent, but circular. I define an inertial frame as one in which the laws of physics take "standard form".
  • · Replies 67 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 51 ·
  • · Replies 57 ·
