| New Reply |
Second derivative of an integral |
Share Thread |
| Dec4-11, 10:58 AM | #1 |
Good day,
I don't understand the following: [tex]\frac{d^{2}}{dt^{2}}\int_{0}^{t}(t-\epsilon )\phi (\epsilon)d\epsilon=\phi''(t)[/tex] All I know is: [tex]\frac{d^{2}}{dt^{2}}\int_{0}^{t}(t-\epsilon )\phi (\epsilon)d\epsilon=\frac{d^{2}}{dt^{2}}\int_{0}^{t}t \cdot \phi (\epsilon)d\epsilon-\frac{d^{2}}{dt^{2}}\int_{0}^{t}\epsilon \cdot \phi (\epsilon)d\epsilon[/tex] Is it allowed to say: [tex]\frac{d^{2}}{dt^{2}}\int_{0}^{t}t \cdot \phi (\epsilon)d\epsilon=\frac{d^{2}}{dt^{2}}\cdot t\int_{0}^{t}\phi (\epsilon)d\epsilon[/tex]? And if so, why is this correct? This is only correct when [tex]t\neq f(\epsilon )[/tex], right? But I am not sure whether this is the case... Thank you in advance! |
| Dec4-11, 11:38 AM | #2 |
Recognitions:
The result (if correct; I haven't checked) will follow from the Liebniz rule:
[tex]\frac{d}{dt}\int_{\alpha(t)}^{\beta(t)} du~f(u,t) = \int_{\alpha(t)}^{\beta(t)}du~ \frac{\partial}{\partial t}f(u,t) + f(t,t)\frac{d\beta}{dt} - f(t,t)\frac{d\alpha}{dt}[/tex] Then you have to do the derivative again, so you would have to use the Liebniz rule on the integral term again. |
| Dec5-11, 09:06 AM | #3 |
[tex]\frac{d^{2}}{dt^{2}}\int_{0}^{t}(t-\epsilon )\phi (\epsilon)d\epsilon=\phi(t)[/tex] |
| New Reply |
Similar discussions for: Second derivative of an integral
| Integral equation with a derivative of the function inside the integral | Calculus & Beyond Homework | 5 | ||
| Derivative of an integral and evaluating an integral | Calculus & Beyond Homework | 7 | ||
| derivative of an integral | Calculus & Beyond Homework | 6 | ||
| some derivative of integral | Calculus | 4 | ||
