New Reply
Find pressure at depth of freshwater
Share Thread
Dec4-11, 02:18 PM   #1
You are scuba diving to reach a ship sunk at a depth of 100m. What is the pressure in atm at this depth? Density of fresh water is 1000kg/m^3 and air pressure at lake surface=1atm=1.013x10^5 N/m^2
2. Relevant equations
P2=P1+pgd
p=density
3. The attempt at a solution
P2=P1+pgd
P2=(1.013x10^5 N/m^2) + (1000kg/m^3)(9.8m/s^2)(100m)
P2=1081300
Its at this point that i get confused. I don't know what the units are for this answer.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Dec4-11, 02:28 PM   #2
You have the correct answer for the pressure in N/m^2
If you are asked for the pressure in atmospheres then you must divide by atmospheric pressure in N/m^2
Dec3-12, 10:37 AM   #3
instead of 9.8 m/s^2 you should use 9.8 N/kg to get correct units
(kg/m^3)(N/kg)(m) will give you N/m^2
Dec3-12, 09:31 PM   #4
Recognitions:
Gold Membership Gold Member
Quote by cc2hende View Post
P2=P1+pgd
p=density
P2=P1+pgd
P2=1081300
Both terms in the equation have to have the same units. That is, the units of the two terms must be consistent. You already know the units of the first term. Just make sure that the units of the second term are consistent. It, of course, helps to know that Newtons are the same kg-m/sec2.
New Reply
Tags
depth, pressure
Similar discussions for: Find pressure at depth of freshwater
Thread Forum Replies
Variation of Pressure with Depth Introductory Physics Homework 3
Depth, Pressure, and Force Introductory Physics Homework 1
Water depth pressure against air pressure Classical Physics 1
absolute pressure. depth Introductory Physics Homework 1
Pressure and depth problem Introductory Physics Homework 1
