Current Mirror Load on Diff Amp
The discussion centers on the function of a current mirror in a differential amplifier configuration, specifically with NPN and PNP transistor pairs. The current mirror converts a differential current input into a single-ended voltage output while minimizing intrinsic losses and maximizing gain. The gain of the differential NPN pair is influenced by the collector load, represented by the formula R_c/(2r'_e), where r'_e is the emitter resistance determined by the tail current. Utilizing a current mirror allows for higher collector resistance, thus enhancing overall gain without incurring significant losses.
  • Understanding of differential amplifiers and their configurations
  • Knowledge of transistor types, specifically NPN and PNP
  • Familiarity with current mirrors and their operational principles
  • Basic grasp of gain calculations in electronic circuits
  • Study the operation of current mirrors in analog circuits
  • Learn about differential amplifier design and performance metrics
  • Explore the impact of collector resistance on amplifier gain
  • Investigate the role of emitter resistance in transistor circuits
Electrical engineers, circuit designers, and students studying analog electronics who seek to deepen their understanding of differential amplifiers and current mirror applications.
smk037
I'm unsure what the purpose of this is. I have looked it up but can only find some explanations stating "role is to convert the differential current input signal to a single ended voltage signal without the intrinsic 50% losses and to increase extremely the gain."
I'm not sure what double ended to single ended voltage signal means, or what the initial intrinsic losses are.
Could someone clear this up for me?
Thanks
Are you referring to the current mirror on top of a differential transistor pair. eg. If you have two NPN to form a differential pair, you have a pair of PNP on top, one PNP has base connected to the collector and the other PNP has the base connect to the base-collector junction that form the current mirror?
If so, the reason is the gain of the differential NPN pair is determined by the collector load. The gain would be [itex]\frac{R_c}{2r'_e}\;\hbox { where }\;r'_e \;\hbox { is the emitter resistance at the given tail current of the transistors where }\; r'_e=\frac 1 {gm}= \frac {V_T}{I_c}≈\frac {25mV}{I_c}.[/itex]
To increase gain, [itex]R_c\;[/itex] has to be as high as possible. The collector resistance of a current mirror has the highest resistance so it give the highest gain. Also a current mirror as the name, reflect the current from one side to the other, that is the reason you don't loss half the gain if you just take one side of the differential amp and drive the next stage.
  • · Replies 31 ·
  • · Replies 26 ·
  • · Replies 47 ·
