Step-Up Current Via Transformer
In summary, John is a mechanical engineer developing a testing apparatus that oscillates a neodymium magnet between two solenoids offset by a 180 degree phase shift. He needs a minimum of 750mA current for each solenoid, but his old function generator has a safety feature that shuts off current at 500mA. To get around this, he has set up an inverting op-amp circuit using a 741 op-amp and plans to push the voltage through a step-down transformer to convert volts to amps. However, simulations in PSPICE show only 400mA output to the solenoids. John is also concerned about the large current predicted to come out of the op-amp, but he is considering using an
John Raines
I'm a mechanical engineer by trade, but I am working on developing a testing apparatus that oscillates a neodymium magnet between two solenoids offset by by a 180 degree phase shift. Basically, one solenoid pushes, the other pulls. To get this, current is essential. I need each solenoid to get a minimum of 750mA. The problem is, the old function generator has a safety feature to shut off current if it exceeds around 500mA.
To get around this, I've set up an inverting op-amp circuit using a 741 op-amp. This kills my current output, but let's me stack energy in voltage. My plan is to push this voltage through a step-down transformer to convert my volts to amps. My understanding is that it's akin to gear ratios: low speed/high torque gets converted to high speed/low torque on a step-down. So I'm wanting high voltage/low current to step down to low voltage/high current. I've crunched the numbers, and my step doesn't seem unreasonable: 70:1. However, when I run the simulations in PSPICE, it shows my circuit only outputting a total of 400mA to my solenoids. Is there something fundamental that I am missing? All I am trying to do is to put a 10Hz AC signal with a current magnitude of 1.5A sent to 2 parallel solenoids.
Also, PSPICE is predicting that this set up leads to a large current coming out of the op-amp. I thought this was impossible? I thought op-amps bump voltage, but kill current? Was I told wrongly on this? Because it would be delightfully simple to just run the output of the op-amp to the solenoids.
Thanks for the help!
-John
Do you have an audio amplifier that you don't mind frying by accident? Hook up the waveform generator to the input and power the solenoids from the output. If it's stereo you can use both channels, one per solenoid. It also allows you to adjust the output with the volume knob.
Likes phinds
That sounds perfect, thank you.
741 is capable of only milliamps, hence milliwatts.
There exist high power op-amps but they tend to be expensive. Last LM12's i bought were over forty bucks apiece but they'll output 6 amps.
You might search on 'power op amp'
but vitro has the better idea - look for a subwoofer amplifier. Audio sites have them aplenty.
@John Raines
While replying to another thread i stumbled across this audio amplifier and thought "That just might drive his electromagnets" .
You'd have to try one out and see if it'll handle the inductance. A couple ohms of resistance will help, perhaps your electromagnet's windings will be enough. ..
http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.CD00001048.pdf
(be aware their drawings are inconsistent as to capacitor numbering . Input capacitors are the 0.22 μf's )
There's a number of kit audio amplifiers available on Amazon for under ten bucks that'd save you from having to lay out a circuit board.
Increasing value of the input capacitors will allow use at lower frequencies.
That one is a linear circuit and straightforward.
There are also "Class D" amplifiers based on digital technology . They're more complex but better suited to high power at low frequency .
Several are based on a very capable TI chip the TPA3116 that is good for two amps of current and can be set for low frequency cutoff as low as 2 hz.. Below that frequency the intelligent amplifier is likely to think there's something wrong and shut down to protect its usual load, a loudspeaker.
Search on those IC numbers with words "amplifier kit"
I get a lot of Amazon hits for pre-assembled kits but can't get any details out of Amazon. Usually those cheap kits just copy the circuit suggested in the IC manufacturer's literature.
The IC manufacturer's datasheet tell you which capacitors determine low frequency cutoff. Better kit manufacturers give you their schematic and board layout in their user manual.
Good Luck - you have a practical and interesting project there.
old jim
Likes John Raines
You could also try putting them in series and use twice the voltage at half the current. You will get a bit of distortion depending on the position of the magnet since it will change the impedance of the solenoids.
BoB
As a matter of conclusion and to help anyone with a similar issue, I figured I should post my results:
I purchased a MAX9744 audio amp from Digi-key. The hardest part was waiting for it to be delivered. I hooked it all up and my oscillator was churning the first time I threw the switch, and the volume nob is especially useful so that I can adjust amperage on the fly. Thanks so much for the advice!
-John
Likes Tom.G and jim hardy
1. What is a step-up current via transformer?
A step-up current via transformer is a device that increases the voltage of an alternating current (AC) by decreasing the current. It consists of two or more coils of wire, known as the primary and secondary windings, which are wound around a metal core. When an AC current is passed through the primary winding, it creates a changing magnetic field in the core, which induces a higher voltage in the secondary winding.
2. How does a step-up current via transformer work?
A step-up current via transformer works on the principle of electromagnetic induction. The changing magnetic field in the core of the transformer induces a voltage in the secondary winding that is proportional to the number of turns in the winding. This results in a higher voltage in the secondary winding compared to the primary winding.
3. What are the applications of a step-up current via transformer?
A step-up current via transformer is commonly used in power distribution systems to increase the voltage of electricity for long-distance transmission. It is also used in electronic devices such as televisions and computers to convert the high-voltage AC power from the outlet to a lower voltage that is safe for the device to use.
4. What are the advantages of using a step-up current via transformer?
The main advantage of using a step-up current via transformer is that it allows for efficient transmission of electricity over long distances. It also allows for the use of lower-gauge wires, which are less expensive and easier to handle. Additionally, it helps to reduce power loss during transmission and ensures a stable and consistent voltage supply.
5. What are the safety precautions when using a step-up current via transformer?
When working with a step-up current via transformer, it is important to follow proper safety precautions to prevent electric shock or injury. These include wearing appropriate personal protective equipment, ensuring the transformer is properly grounded, and using caution when handling high-voltage components. It is also important to regularly inspect the transformer for any signs of damage or wear and to have it professionally maintained and tested as needed.
  • Electrical Engineering
