| New Reply |
Simply Supported Beam Question |
Share Thread | Thread Tools |
| Dec5-11, 03:17 AM | #1 |
Question: Sketch the cross section of the gantry girder and indicate on it the position of the maximum bending stress. State if this stress is tensile or compressive for this particular example, explain how you decided 2. Relevant equations There aren't any required Relevant information however: The Beam is Hogging and the Maximum Bending Stress is positive 3. The attempt at a solution I've sketched the cross-section and previously indicated the maximum bending stress on the top to indicate the tensile factor. However this is wrong and instead is Compressive. What i struggle with is explaining why this is the case. ___________ |..................| .......|....| .......|....| .......|....| .......|....| ____|....|____ |..................| .......... [itex]\sigma[/itex] This is the cross section with the sigma sign beneath to indicate the max bending stress is compressive. Just to show visually what i've done. I just need help explaining why it would be compressive / how i decided. Just to clarify, i didn't decide this, i was told by my tutor but i have to figure out why and theres nothing out there on the internet that discusses this. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec5-11, 03:23 PM | #2 |
If a beam is 'hogging', it is deflecting upward, that is, it has upward curvature. This tends to expand (stretch) the topmost fibers and to compress (squeeze) the bottom fibers, as you can see by drawing a quick sketch. The top fibers would be in tension and the bottom fibers would be in compression. For a symmetric beam, these 2 stresses would be equal. If the beam is not symmetrical, which apparently is your case, the max stress occurs at the outmost fibers of the flange furthest from the neutral axis.
| New Reply |
| Thread Tools | |
Similar Threads for: Simply Supported Beam Question
| Bending of Simply Supported Beam | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Simply Supported Beam Safe load | Engineering, Comp Sci, & Technology Homework | 33 | ||
| Stress, Deflection for a simply supported beam with UDL applied | Mechanical Engineering | 9 | ||
| Radius of Curvature in a simply supported beam | Introductory Physics Homework | 7 | ||
| Simply Supported Beam | Mechanical Engineering | 2 | ||
