Calculating Object Density with Formulae
  • Thread starter Thread starter Haftred
    Density Formulae
The discussion revolves around calculating the density of an object using various formulae related to buoyancy and Archimedes' principle. Participants are exploring the relationship between apparent weight, buoyant force, and fluid density in the context of density calculations.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster questions the validity of two different formulae for calculating density. Some participants elaborate on Archimedes' law and the concept of buoyant force, while others express confusion about the application of these principles.
There is ongoing exploration of the formulae and their implications. Some participants affirm the correctness of the original formulas, while others suggest simpler approaches to calculating density without involving buoyant forces. The discussion reflects a mix of interpretations and attempts to clarify the concepts involved.
Participants are navigating the complexities of buoyancy and density calculations, with references to Archimedes' law and the assumptions regarding fluid incompressibility. There is a noted frustration from the original poster regarding the clarity of the problem.
Haftred
Can I use either of these formulae to find the desity of an object?
a) ((Weightapparent/Forcebuoyant) + 1)(Densityfluid) = Densityobj
b) (Weightobject/Forcebuoyant *Densityfluid) = Densityobj
Thanks
Archimedes law tells you the buoyance force is equal to the gravitational force on the displaced mass:
[tex]F_{buoyance}=g \rho_{fluid} V_{displaced}[/tex]
The apparent weight of the object can be found by evaluating the net downward force [itex]F_g-F_{buoyance}=g[m-\rho_{fluid} V_{displaced}][/itex] Where the term between brackets is the apparent weight.
With [itex]\rho[/itex] density, [itex]m[/itex] mass [itex]V[/itex] volume and g the gravitational acceleration. With this knowledge you can probably work out the answer yourself!
I still can't figure it out :mad:
What's to figure out than applying what Da-willem said??
You may want to write:
[tex]\rho_{body}-\rho_{fluid}=\frac{F_g-F_{buoyance}}{g V_{displaced}}[/tex]
From the previous equation,the density of the body is immediate.
ok, so my original two formulas are correct then, right?
Yes,they are true.But why complicate with calculating buoyant forces,when u can simply say that:
[tex]\rho_{object}=\frac{m_{object}}{V_{displaced}}[/tex]
It's Archimede's law that states that,if the fluid is incompressible (Archimedes didn't think of compressible fluids),then the volume of the body is equal to the volume of the displaced fluid.Since u can easily determine one's body mass,the density is immediate.
Daniel.
  • · Replies 24 ·
  • · Replies 23 ·
