Heat energy transferred in converting ice into steam
The problem involves calculating the heat energy required to convert 0.10 kg of ice at -10 degrees Celsius into steam at 100 degrees Celsius, encompassing multiple phases of heating and phase changes.
  • Mixed
  • Participants discuss the stages of heating ice to water and then to steam, questioning the calculations and the specific heat capacities used. There is an exploration of the latent heat values and their impact on the total energy calculation.
Some participants have provided calculations for each stage of the process, leading to a total energy requirement that aligns with a reference value. There is acknowledgment of a potential miscalculation regarding the latent heat of vaporization, prompting further clarification and verification of values used.
Participants note the importance of checking calculations and the potential for misprints in reference materials, which may affect the understanding of the problem.
physiman
1. Homework Statement
Calculate the heat energy required to convert 0.10 kg of ice at -10 degrees celsius into steam at 100 degrees celsius.
2. Homework Equations
E = m c dt (1)
where
E = heat energy (kJ)
m = unit mass (kg)
c = specific heat capacity (kJ/kg oC)
dt = temperature change (Kelvin or degrees Celsius)
3. The Attempt at a Solution
Given in the question:
m = 0.1 kg
dt = 100-(-10) = 110 degrees celsius
c = 2100 J Kg^-1 K^-1 (specific heat capacity of ice)
So what I did was using the equation:
E = m c dt
E = (0.1)(2100)(110)
E = 23100 J
which would be 23.1 kJ
The problem is that the answer section of the book says 301.6 KJ which is way above my result.
What's the mistake I'm doing?
Help appreciated.
Ice must be heated to 0C; ice must then be converted into liquid water at 0C;
Water at0C must be heated to 100C; water must be converted to vapor (steam) at 100C.
There are 4 stages, each requiring heat energy
Thanks for the hint.For Ice -> water:
m = 0.1kg c=2100 J kg^-1 K^-1 dt = 10 degrees (-10 -> 0)
therefore E= mc dt = 0.1(2100)(10) = 2100 J
Energy required to melt the ice:
E= specific latent heat of fusion of ice * mass
= 325000(0.1)
= 32500 J
and then for water to steam:
m = 0.1 kg c= 4200 J kg^-1 K^-1 (for water) dt= 100 degrees (0->100)
=> E= 0.1 (4200) (100) = 42000 J
Energy required to vaporize 0.1 kg of water:
E = specific latent heat of vaporization of water * mass
= 225000(0.1)
= 22500 J
then i add them
2100 + 32500 + 42000 + 225000
and get 301600 J which is 301.6 kJ.Thank you.
That looks good.
Well done
Do you see that by far the greatest amount of energy is in converting liquid water to steam?
SORRY... misprint, you have the latent heat of vaporisation to convert water to steam out by factor of 10
Latent heat of vaporisation = 2300000 J/kg
I have only just noticed... fortunately you made a mistake in your multiplication so your answer is correct6.
should always double check calculations !
  • · Replies 17 ·
10K
