What is the result of this laser/time dilation scenario?
  • Context: Graduate
  • Thread starter Thread starter Acumen
    Dilation
The discussion revolves around a scenario involving two observers, A and B, where A fires a laser at beacons while B travels perpendicularly at a speed resulting in time dilation. The participants explore the implications of special relativity on the observations of both observers regarding the number of beacons hit by the laser and the perceived speed of light.
  • Observer A posits that they see 4 beacons hit while B sees only 1 beacon hit due to time dilation.
  • Some participants suggest that both observers would see 2 beacons hit, raising questions about the implications of light traveling faster than the speed of light.
  • Concerns are raised about the effects of length contraction on the distances between beacons from B's perspective, with some arguing that distances should remain unchanged since the laser is fired perpendicularly.
  • Participants discuss the necessity of a reflector for B to measure the speed of light accurately, given that B is in a non-inertial frame.
  • There is a debate about whether non-inertial frames allow for perceived speeds faster than light, with references to the concept of proper velocity.
  • Some participants express confusion over how B can perceive signals traveling distances that imply superluminal speeds, questioning the validity of their observations.
Participants do not reach a consensus on the number of beacons hit or the implications of B's observations regarding the speed of light. Multiple competing views remain regarding the effects of time dilation, length contraction, and the nature of measurements in non-inertial frames.
The discussion includes assumptions about the behavior of light in different frames of reference and the implications of special relativity that remain unresolved. The definitions and characteristics of non-inertial frames are also debated without reaching a clear conclusion.
Acumen
At an origin there is an observer (A) who fires a laser at a series of beacons in a straight line spaced 186,000 miles (1 light second) apart each.
At the same time as the laser is fired, a second observer (B) starts traveling on a path perpendicular to that of the laser, stopping and returning along the same path so that they return to the origin. B travels at such a speed so that there is a 4 to 1 time dilation for the total time of his journey.
When B returns to the origin, A's clock sees 4 seconds have passed, B's clock sees 1 second passed. What is the resulting state of the beacons for both observers?
As I understand it, the result should be that:
A sees 4 beacons have been hit by the laser.
B sees 1 beacon has been hit by the laser.
How does SR explain that when B returns 4 beacons have been hit?
They both will see that two beacons have been hit.
Yes that much better than 4, oops. So that makes sense to me for A, but if B sees 2 are hit, that means that the light traveled 744,000 miles (round trip 2 beacons) in 1 of B's seconds. That would mean it traveled faster than the speed of light, no?
No. For one thing, due to length contraction, the distance between beacons will only be 1/4 light year for B, and for the other, B would measure light as traveling at c relative to himself, it would be the beacons that would be moving, first towards him and then away.
I was under the impression length only contracted in the direction of motion? Since the laser is perpendicular should not the distances remain the same?
Also if B does observe 2 beacons hit due to contraction, to me it seems that even though the speed of the laser is constant, that the speed of contraction and expansion exceeded the speed of light?
The second beacon would contract from 372,000 to 93,000 and expand to 372,000 = 558,000 mile round trip contraction and expansion in 1 second.
Is this faster than light contraction allowed?
When you measure the speed of light, you have to remain at a constant velocity during your measurement and it requires a mirror placed some constant measured distance away from you and you need a clock to measure how long it takes for the light to make a round trip, so while B is traveling away from A at right angles to the direction the laser is pointing in, he can't measure that light. He needs A to fire another laser pointing in his direction. Or you could have said there was a bright flash of light traveling in all directions. Then he can make a measurement of the round-trip speed of light as he's traveling away and then make another measurement as he's coming back.
But some time during his trip, he will be able to see the light reflecting off the first beacon (assuming it reflects in all directions) but he won't see the light reflecting off the second beacon until the moment he gets back.
I think you overlooked the fact that B is traveling at right angles to the direction the laser is pointing and to where the beacons are located.
So even if he never observes the laser hitting the second beacon until the moment he returns, hasn't he now had only 1 second pass and sent information 744,000 miles? Does this not mean that even though he knows 4 seconds passed from A's perspective, that from his perspective a signal was sent faster than the speed of light?
No, as I said, if he wants to measure the speed of light, he needs a reflector that is traveling with him. The beacons are not traveling with him.
B's frame is non-inertial, so it is expected for light to travel at speeds other than c in it.
So as I understand it, non-inertial frames allow things to travel with a perceived speed faster than light, which is called proper velocity?
Why would the beacons need to be traveling with B if he only records the light when he is about to leave and as soon as he returns to the inertial frame?
Proper velocity does not apply to light.
Special Relativity defines the progress of light to be c in any inertial frame. There is no standard way to define the characteristics of a non-inertial frame, but in general, you cannot consistently define the speed of light to be c everywhere in it for all times and in all directions like you can with an inertial frame. The reason we need to define the speed of light is because we cannot observe the progress of light like we can observe the progress of moving material objects that always travel at less than the speed of light. We use light to observe these objects but there is nothing faster than light with which to observe light so its progress will remain a mystery apart from a definition of a Frame of Reference.
I'm not sure if you're asking about observer A measuring the round trip speed of light from him to the second beacon and back to him, or defining the one-way speed of light according to an inertial frame in which he is at rest. In either case, your scenario doesn't allow him to do either one.
Yes.
Proper velocity is not a commonly used concept. I am not familiar enough with it to talk about its behavior in non-inertial frames.
  • · Replies 20 ·
  • · Replies 42 ·
  • · Replies 16 ·
  • · Replies 46 ·
  • · Replies 58 ·
  • · Replies 23 ·
  • · Replies 26 ·
