Differential equation asymptotes
The discussion revolves around understanding horizontal asymptotes in the context of differential equations. Participants are exploring the implications of the equations dy/dx = x - 2 and dy/dx = y - 2, questioning how to determine the existence of horizontal asymptotes without solving the equations explicitly.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants are questioning the relationship between the values of x and y in determining horizontal asymptotes. They discuss the conditions under which dy/dx approaches zero and the implications for the behavior of the function as x approaches infinity.
There is active engagement with various interpretations of the conditions for horizontal asymptotes. Some participants suggest that the behavior of dy/dx at specific values of y indicates the presence of an asymptote, while others express uncertainty about the generalizability of this reasoning. The discussion is ongoing, with no clear consensus reached.
Participants are grappling with the definitions and implications of horizontal asymptotes in differential equations, particularly in relation to the specific examples provided. There is a noted lack of explicit consensus on how to approach the problem without solving the equations.
lpbug
Hi guys, I just have a very broad and general question.
Today in math class I was asked to solve the horizontal asymptote of a differential equation, and this had me stumped.
Later on, the teacher gave me the following two examples:
dy/dx=x-2
and
dy/dx=y-2
The solution to the first equation for a horizontal asymptote is DNE
The solution to the second is 2
Now, I'm just wondering... How would one know that this is true without solving for the original equation? I mean, this doesn't seem intuitive at all to me. Why is it that when X is what makes the differential equation 0 there is no asymptote and when Y makes the equation 0 there is?
Thanks for all the help.
If you have a horizontal asymptote then as x approaches infinity, dy/dx has to approach zero, right?
but isn't it not enough information just to assume that whenever dy/dx=0 when the y value is making the dy/dx 0? I mean, I see where you're coming from with as x approaches negative infinity or infinity dy/dx has to approach 0 but I don't understand how you can just tell from the equation that a dy/dx involving a y will DEFINITELY have a horizontal asymptote. Is it because all forms of differential equation involving y will have a solution like e^something?
Also, the reason for dy/dx being zero if y is a certain number implying a horizontal asymptote is simple: If when y is a certain number, then dy/dx is zero, then the graph is going to be flat at that point. This means that y won't change as x changes, but since y doesn't change, then dy/dx is going to stay zero. Hence, horizontal asymptote.
aha! I think i got it, so if the slope of dy/dx is 0, either the change in y (dy) must equal 0 OR the change in x (dx) must be infinity? and if the y isn't changing, then the slope will not change after it theoretically reaches 0, because dy/dx is dependent on y itself?
Well, you can definitely say that the first equation doesn't have an asymptote. In the second equation there is at least a possible y value for a horizontal asymptote. One way to look at it is if y>2 then the function y is increasing. If y<2 it's decreasing. Imagine what must happen as x->-infinity.
