Finding a in circular motion problem
The problem involves a stone released from a sling in circular motion, with parameters including a radius of 1.5m, a height of 2m above the ground, and a horizontal distance of 10m from the release point. The goal is to determine the acceleration during the circular motion, with some participants noting discrepancies in their calculations.
  • Mixed
  • Participants discuss the need to calculate time and velocity to find acceleration, with some questioning the appropriateness of using free fall equations in the context of circular motion. Others suggest working backward from the known parameters to derive the necessary values.
There is an ongoing exploration of the problem, with participants providing insights into the relationships between the variables involved. Some guidance has been offered regarding the correct equations to use, but no consensus has been reached on the final approach or calculations.
Participants note that the problem does not provide an explicit velocity, leading to various interpretations and methods for deriving it. There is also a correction regarding the units of acceleration mentioned in the discussion.
infraray
The problem is this: sling with r=1.5m spinning 2m above ground. Stone is released and lands 10m away. What is acceleration while in circular motion? The answer is supposed to be 160 m/s. I keep coming up with approx. 145 m/s. I assume I am to figure t first to then find v, where t= sqrt(2y/g), which yields approx. 0.64s. Where am I going wrong? I have tried this many different ways and am pulling my hair out. Any help or leads will be greatly appreciated. Thanks.
That equation is for free fall, not for circular motion.
The acceleration of a particle undergoing uniform circular motion is
aC=v2/r. You need to know how fast the mass is moving.
Maybe I am missing something, but the problem isn't doesn't contain velocity as a given, the only givens are: r=1.5m, y=2m, and x=10m. I assume I am to figure out the initial v as the stone leaves the sling and work backward to find a. Once again I preemtively thank anyone who can offer some advice.
You know the height of the stone when it is "released" from the sling and you know it was moving horizontally at that time. The motion of the stone from that point is y= (-g/2)t^2+ 2 and x= v t.
You know that when y= 0, x= 10 m. You should be able to solve the equations (-g/2)t^2+ 2= 0 for t (yes, t= sqrt(2y/g) which, since y= 2, is t= 2/sqrt(g)) and then v t= 10 for v. THAT gives you the speed of the stone. Knowing that you can use the formulas for circular motion (particularly a= v^2/R) to find the acceleration, a.
By the way, you say that "The answer is supposed to be 160 m/s."
Of course, that's impossible: I'm sure you mean 160 m/s^2.
Actually, I get 163 1/3 meters per second squared.
Thanks HallsofIvy! What was messing me up was trying to calculate the velocity by using the formula v=c/t where c is the circumference. I was assuming that because I was looking for the acceleration while in circular motion I should have been using that formula. It all works out fine now. Oh, yeah I realize the 160 m/s should have contained the square I apparently did not proof read well enough. Thanks again for your help.
