Relative speed, relative angles
The discussion focuses on a physics problem involving a kayaker paddling north across a harbor while being affected by a tidal current flowing east at 2.0 m/s. The kayaker's paddling speed is 3.0 m/s, and to maintain a straight path north, he must paddle at an angle θ west of north, calculated to be approximately 41.8 degrees. The velocity components are defined using the equations v = v + V, where the x-axis represents east and the y-axis represents north. The confusion arises from the use of sine and cosine in determining the velocity components, particularly why the x-component is negative and how the relationship sin(θ) = 2/3 is derived from the current's speed relative to the kayaker's speed.
  • Understanding of vector addition in physics
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with coordinate systems in physics
  • Basic principles of relative motion
  • Study vector addition in two dimensions
  • Learn about the application of trigonometric functions in physics problems
  • Explore relative motion concepts in fluid dynamics
  • Investigate real-world applications of current effects on navigation
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators seeking to clarify concepts of relative motion and trigonometry in practical scenarios.
skysunsand
A kayaker needs to paddle north across a 100-m-wide harbor. The tide is going out, creating a tidal current that flows to the east at 2.0 m/s. The kayaker can paddle with a speed of 3.0 m/s.
v= v + V
Let the Earth frame be S and a frame attached to the water be S .′ Frame S′ moves relative to S with velocity V. We define the x-axis along the direction of east and the y-axis along the direction of north for both frames.
Solve: (a) The kayaker’s speed of 3.0 m/s is relative to the water. Since he’s being swept toward the east, he
needs to point at angle θ west of north. In frame S′, the water frame, his velocity is
v= (3.0 m/s, west of north) = (-3.0sin m/s) (3.0cos m/s)
v= (-3 sin [itex]\theta[/itex] + 2 ) i + (3 cos [itex]\theta[/itex])
In order to go straight north, v=0
so sin theta = 2/3 = 41.8 degrees
The solution is above. I just don't understand what it's telling me. Why am I using cosine for Y, if cos = adjacent/hypotenuse, which is for X values?
Why is it -3 for x, instead of positive 3?
What in the world does sin theta = 2/3 have to do with this, and why does it work out like that?
If anyone can help clarify what the solution is trying to tell me, it would be very much appreciated.
v= v + V
The solution is taking North as the Y-direction, and East as the X-direction.
With the direction referrig to an angle West of North. the westerly component [x] is thus negative; and the North component [y] is positive.
EDIT: the sin theta equalling 2/3 is because the current is 2 m/s whle the kayaker is paddling at 3 m/s
also it is not -3 for X, it is -(3.sintheta)
  • · Replies 38 ·
  • · Replies 16 ·
