Calculating Magnetic Flux: Plane with Rotated Wire and Current of 2.5 A
The magnetic flux crossing the portion of the plane defined by 0.01 m < r < 0.05 m and 0 m < z < 2 m, with a current of 2.5 A flowing along the z-axis, is calculated to be 0.00000785 Wb. The magnetic field around a long wire is given by B(r) = (μ0 I)/(2π r), where μ0 is the permeability constant. The area of the circular portion of the plane is determined using A = πr^2, resulting in an area of 0.00785 m². The angle between the normal to the plane and the magnetic field is π/4, leading to the final flux calculation using Φ = BAcos(θ).
  • Understanding of magnetic flux and its calculation
  • Familiarity with the Biot-Savart Law and magnetic fields around current-carrying wires
  • Knowledge of calculus for integration and area calculations
  • Basic understanding of trigonometry, particularly cosine functions
  • Study the Biot-Savart Law for detailed understanding of magnetic fields
  • Learn about the permeability constant (μ0) and its significance in electromagnetism
  • Explore advanced applications of magnetic flux in electromagnetic theory
  • Investigate the effects of varying current on magnetic field strength and flux
Physics students, electrical engineers, and professionals involved in electromagnetism and magnetic field analysis will benefit from this discussion.
hd28cw
Find the magnetic flux crossing the portion of the plane
theta = x/4 defined by 0.01 m < r <0.05 m and 0 m < z < 2 m. A current of 2.50 A is flowing along z-axis along a very long wire.
in drawing the picture i know that there is a long thin wire with a current of 2.5 amps flowing positively on the z-axis and the plane is lying rotated at an angle of pi/4 with the magnetic field flowing in a counter clockwise direction.
How do I go about finding the magnetic flux.
Please help.
Should that be theta=pi/4?
[tex]\Phi_B=\int_P \vec B \cdot d\vec a[/tex]
Since the plane lies parallel with the z-axis, its normal points in the same direction as the magnetic field everywhere in the plane, so you can drop the dot in the integrand
[tex]\Phi_B=\int_P B da[/tex]
Recall that the magnitude of the magnetic field of a long wire is:
[tex]B(r)=\frac{\mu_0 I}{2\pi r}[/tex]
where r is the distance from the wire.
To calculate the magnetic flux, we can use the formula Φ = BAcosθ, where Φ is the magnetic flux, B is the magnetic field, A is the area, and θ is the angle between the normal to the area and the magnetic field. In this case, we have a wire with a current of 2.5 A flowing along the z-axis, which creates a magnetic field around it. The plane is rotated at an angle of π/4, so the angle between the normal to the plane and the magnetic field is also π/4.
First, we need to find the magnetic field at the given point on the plane. Using the right-hand rule, we can determine that the direction of the magnetic field is out of the page. The magnitude of the magnetic field can be calculated using the formula B = μ0I/2πr, where μ0 is the permeability constant, I is the current, and r is the distance from the wire. In this case, r = 0.05 m. Plugging in the values, we get B = (4π×10^-7 T⋅m/A)(2.5 A)/(2π×0.05 m) = 0.001 T.
Next, we need to calculate the area of the portion of the plane defined by the given values of r and z. Since the plane is a circle, the area can be calculated using the formula A = πr^2. In this case, r = 0.05 m, so A = π(0.05 m)^2 = 0.00785 m^2.
Finally, we can plug in the values into the formula Φ = BAcosθ. Since θ = π/4, we get Φ = (0.001 T)(0.00785 m^2)cos(π/4) = 0.00000785 Wb. Therefore, the magnetic flux crossing the portion of the plane is 0.00000785 Wb.
  • · Replies 31 ·
  • · Replies 29 ·
