How Do You Calculate the Kinematics of Touching Spheres Under External Force?
The discussion revolves around calculating the kinematics of two touching spheres under an external force. The original poster describes a scenario involving two spheres with specified masses and radii, where an external force acts on one sphere. The challenge lies in determining the forces between the spheres and their resulting motion, particularly in the absence of gravity and friction.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the nature of the external force and its application point, questioning whether it acts normally on the surface or through the center of mass. There are discussions about writing equations based on Newton's second law and the constraints imposed by the spheres touching each other. Some participants suggest treating the problem similarly to a sloped block scenario, while others express concerns about the complexity of the equations involved.
The discussion is active, with various interpretations and approaches being explored. Participants have provided insights into the relationships between forces and constraints, and there is an ongoing examination of how to express the motion of the center of mass and the normal forces involved. While no consensus has been reached, several productive lines of reasoning have been proposed.
Participants note the absence of friction and gravity as significant constraints in the problem. The original poster clarifies that this inquiry is not for a class assignment but stems from personal curiosity about the kinematics involved.
dougla
My physics classes were a long time ago, and I can't for the life of me remember how to solve this problem: If I have two spheres s1 and s2 touching, of mass m1 and m2, with radii r1 and r2, and centers c1 and c2, and I have a force Fout normal to the surface of s1, how do I calculate the kinematics of the two spheres? Picture here:
So there is Fout, acting on s1, and there must be F12, normal to the tangent where s1 and s2 meet acting on s2, and s21, opposite to F21, acting on s1, with F12 + F21 = 0; Beyond this, however, I am totally lost as to how to find what F12 and F21 are.
Also, there is no gravity and no friction.
Um - is Fout normal everywhere on the surface of S1 or is it an applied force acting through the center of mass of the sphere?
If the latter, F12 is the component of Fout in the direction of c2. There will also be a perpendicular component which will tend to make the sphere's rotate.
Write out Newton's second law for both spheres in terms of Fout and the unknown normal force F12. Write the equation of the constrain, too, that the spheres have to touch each other. Without friction, you do not need to take rotation of the spheres into account.
ehild
Yes, Fout is an applied force acting on the center of mass of the sphere.
I don't think F12 is merely the component of Fout in the direction of c2, though obviously it's a scalar multiple of c2. Consider if Fout were coming from directly opposite S2. In that case, it would be like pushing two boxes, and thus F12 = m2 * a, with a = Fout / (m1 + m2), so F12 = Fout * m2 / (m1 + m2).
Also, since there is no friction, why would there be rotation on these spheres?
The normal force is not known and it need not be constant during the motion. If you take the system of spheres, the motion of CM is determined by the external force: the normal force cancels.
Write all equations both for x and y directions using the angle between the external force and the radius to the common point to the spheres, and then cancel the normal force.
ehild
Can I treat the instantaneous force as the force on a sloped block?
The constraint on this one is
[tex]a(x_2 - x_1) + b(y_2 - y_1) = c[/tex]
which differentiates into
[tex]a(\ddot{x}_2 - \ddot{x}_1) + b(\ddot{y}_2 - \ddot{y}_1) = 0[/tex]
which is nice and linear. Whereas the circle constraint is
[tex](x_2 - x_1)^2 + (y_2 - y_1)^2 = D[/tex]
and thus,
[tex]2(x_2 - x_1)(\ddot{x}_2 - \ddot{x}_1) + (\dot{x}_2 - \dot{x}_1)^2 + 2(y_2 - y_1)(\ddot{y}_2 - \ddot{y}_1) + (\dot{y}_2 - \dot{y}_1)^2 = 0[/tex]
which is horrifying.
edit: although since they are at rest at the start, this should transform back into the original constraint, so, I guess I can.
This problem looks horrifying anyway. What was the original question?
ehild
Actually it turns out the sphere constraint is identical to the sloped block constraint, though obviously the slope varies.
Since we know that [tex](\dot{x}_2 - \dot{x}_1)^2 + (\dot{y}_2 - \dot{y}_1)^2 = 0[/tex]
then
[tex]2(x_2 - x_1)(\ddot{x}_2 - \ddot{x}_1) + (\dot{x}_2 - \dot{x}_1)^2 + 2(y_2 - y_1)(\ddot{y}_2 - \ddot{y}_1) + (\dot{y}_2 - \dot{y}_1)^2 =[/tex]
[tex]2(x_2 - x_1)(\ddot{x}_2 - \ddot{x}_1) + 2(y_2 - y_1)(\ddot{y}_2 - \ddot{y}_1) = 0[/tex]
where the slopes are [tex]a = (x_2 - x_1), b = (y_2 - y_1)[/tex]
This isn't a question for a class, I'm just curious about how to solve this problem.
You have got equations following from the constraint. You also have Newton's equations between accelerations and forces. Those four equations contain the unknown normal force.
It is possible to use the coordinates of the CM and the difference between the coordinates as new variables.
The motion of the CM is easy to solve, it depends solely on the external force.
The difference between the coordinates can be expressed with an angle and with the constant distance (r1+r2).
At a certain angle, the spheres separate and the constraint does not act any more. From that instant, you have a free sphere and the other one moving under the effect of the external force. ehild
13K
  • · Replies 32 ·
  • · Replies 39 ·
