SCR and Diode are Active or Passive Components?
The discussion revolves around whether SCRs (Silicon Controlled Rectifiers) and diodes should be classified as active or passive components. Participants explore definitions and characteristics of these components, touching on their roles in circuits and energy management.
  • Some participants assert that a diode is a passive device, specifically a non-linear passive device, while an SCR is classified as an active device due to its ability to control current flow based on an applied gate signal.
  • Another viewpoint suggests that active components are those that supply power, while passive components absorb or dissipate power, leading to confusion regarding the classification of SCRs and diodes.
  • One participant mentions that diodes can be used in applications such as mixers and oscillators, which could imply they might be considered active devices in those contexts, although they are primarily viewed as non-linear passive devices when used as rectifiers.
  • Another participant argues that both diodes and SCRs can be classified as active devices, citing their I-V curves that resemble current or voltage sources, and noting that all semiconductor devices are generally considered active except for semiconductor resistors.
Participants do not reach a consensus on the classification of diodes and SCRs, with multiple competing views presented regarding their status as active or passive components.
The discussion highlights varying definitions of active and passive components, which may depend on context and application, leading to differing interpretations among participants.
otomanb
Hello!
Please clarify the definition of Active and passive components. I have some confusion in it!
Regards
otoman
A diode is a passive device - a non-linear passive device specifically.
An SCR is an active device.
An active device is able to take a signal and amplify or add energy to the signal. With an SCR, the applied gate signal voltage will turn on the SCR to pass current through, so it can pass more energy out than was put into it from the signal.
A diode is passive because no matter what signal enters the anode, the diode will drop energy across it. One exception that a diode can be considered as an active device is when it is used as a switch, but even then I am not sure since the diode is not using any power source to do this switching.
but i read somewhere on wikiuniversity.com that those components that supply power like battery etc are active components and those components that absorb or dissipate power.
In SCR we basically control the triggering pulse so get desired power/output!
it's mean if firing angle is 90deg then the output will be half. so SCR is not amplifying power
Here, I found this. Maybe it will help you.
http://www.allaboutcircuits.com/vol_3/chpt_1/2.html
You should do your own homework.
Getting answers from sites like this does not do you any good and distracts from those that actually need help.
Diodes can be used as mixers, and oscillators, so I think they should sometimes be classified active devices. But as a rectifier, I guess it's a non-linear passive device.
@Carl Pugh
thanks you sir
Active devices are energy sources and are capable of modifying or processing the signal.
Both diode and SCR are active devices along with MOSFET and BJT and many others. You can tell an avtive device by looking at their I-V curve. They approximately look like current or voltage sources. BJT and MOSFET has I-V curve similar to a current source. Diode has I-V curve similar to a voltage source. While BJT and MOSFET can be used both as amplifiers or active load, diode can only be used as active load. Much the same goes for SCR. Interestingly, all semiconductor devices are active devices except semiconductor resistor ignoring its non-ideal behavior.
thanks sir
  • · Replies 27 ·
  • · Replies 32 ·
