How Is Magnetic Flux Calculated Near a Current-Carrying Wire?
The magnetic flux crossing the specified portion of the plane defined by 0.01 m < r < 0.05 m and 0 m < z < 2 m, with a current of 2.50 A flowing along the z-axis, is calculated to be 1×10^-6 T⋅m². The magnetic field (B) at a distance r from the wire is determined using the formula B = μ₀I/(2πr), resulting in B = 1×10^-5 T. The area (A) through which the magnetic field passes is calculated as A = 0.1 m². The final magnetic flux is derived from the equation Φ = B⋅A.
  • Understanding of magnetic fields from current-carrying conductors
  • Familiarity with the concept of magnetic flux
  • Knowledge of the right-hand rule for determining magnetic field direction
  • Ability to perform calculations involving area and magnetic field strength
  • Study the derivation of the magnetic field around a long straight wire using Ampère's Law
  • Learn about the applications of magnetic flux in electromagnetic theory
  • Explore the impact of different angles on magnetic flux calculations
  • Investigate the effects of varying current on magnetic field strength and flux
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetic theory or applications related to magnetic fields and flux calculations.
hd28cw
Find the magnetic flux crossing the portion of the plane
theta = x/4 defined by 0.01 m < r <0.05 m and 0 m < z < 2 m. A current of 2.50 A is flowing along z-axis along a very long wire.
in drawing the picture i know that there is a long thin wire with a current of 2.5 amps flowing positively on the z-axis and the plane is lying rotated at an angle of pi/4 with the magnetic field flowing in a counter clockwise direction.
How do I go about finding the magnetic flux.
Please help.
Well first one has to find the magnetic field (B) at some distance r from the conductor.
This problem is a little complicated since one has a plane tilted at 45° from the plane passing through the conductor. If the plane was vertical, then the magnetic field would simply be a function of r.
But since the plane is tilted, as one ascends the plane, the distance from the conductor increases.
So can you write an equations for the distance of a point on the plane from the conductor.
Now since the plane is tilted pi/4 or 45°, a point on the tilted plane is a distance z from the vertical plane, so the distance (d) from the conductor is just d=sqrt(r^2+z^2).
See if can use that with the definition of magnetic flux.
To find the magnetic flux crossing the portion of the plane defined by the given parameters, we can use the formula for magnetic flux, which is given by Φ = B⋅A, where B is the magnetic field and A is the area through which the field passes. In this case, we know that the current is flowing along the z-axis, so the magnetic field will also be in the z-direction.
To calculate the magnetic flux, we first need to find the magnetic field at the given point. Using the right-hand rule, we can determine that the direction of the magnetic field will be in the counterclockwise direction. We can also use the formula for the magnetic field produced by a long straight wire, which is given by B = μ₀I/(2πr), where μ₀ is the permeability of free space, I is the current, and r is the distance from the wire.
Since the current is given to be 2.50 A and the distance from the wire is 0.01 m < r < 0.05 m, we can calculate the magnetic field at this point to be B = (4π×10^-7 T⋅m/A)(2.50 A)/(2π(0.05 m)) = 1×10^-5 T.
Next, we need to find the area through which the magnetic field passes. From the given parameters, we know that the area is defined by 0.01 m < r < 0.05 m and 0 m < z < 2 m. This forms a rectangular area with a length of 0.05 m and a width of 2 m. Therefore, the area is A = (0.05 m)(2 m) = 0.1 m².
Plugging in the values for the magnetic field and area into the formula for magnetic flux, we get Φ = (1×10^-5 T)(0.1 m²) = 1×10^-6 T⋅m². Therefore, the magnetic flux crossing the portion of the plane is 1×10^-6 T⋅m².
I hope this helps you understand how to calculate the magnetic flux for a given scenario. If you have any further questions, please do not hesitate to ask.
