Electric potential inside a spherical shell
The discussion focuses on the electric potential inside a spherical shell with outer radius b and inner radius a, containing a total charge of +3q and a point charge of -q at its center. The electric field outside the shell is defined as E = (3q - q)/(4πr²ε₀). The electric potential inside the shell is determined to be 2q/(4πb²ε₀), as there is no electric field within the shell. The confusion arises when comparing electric potentials at different reference points, specifically between the shell's potential and the potential due to the point charge.
  • Understanding of electric fields and potentials
  • Familiarity with Gauss' Law
  • Knowledge of spherical coordinates in electrostatics
  • Basic calculus for integrating electric fields
  • Study the application of Gauss' Law in electrostatics
  • Learn about electric potential and field relationships in spherical geometries
  • Explore the concept of induced charges on conductors
  • Investigate the integration of electric fields to find electric potentials
Students and professionals in physics, particularly those focusing on electrostatics, electrical engineers, and anyone interested in understanding electric potentials in spherical charge distributions.
TrolliOlli
Say we have a spherical shell of outer radius b and inner radius a. The shell has a total charge +3q and at it's center is a point charge of charge -q. I know that the E field for r>b would simply be: E = (3q-q)/(4πr^2ε0) and thus the electric potential inside the shell must be the same as the electric potential on the outer shell since there is no E field inside the shell. This brings me to the conclusion that the electric potential inside the shell is simply 2q/(4π(b^2)ε0).
This confuses me however as can't it be said that if we take the electric potential at A with respect to the point charge, we get -q/(4π(a^2)ε0)? How can this be the case at the inner surface of the shell if the shell itself has an electric potential of 2q/(4π(b^2)ε0)?
Am I looking at this wrong as in one case I'm comparing to infinity and in the other I'm comparing with the point charge? If this is the case does this mean the electric potential at the center of the sphere would simply be 2q/(4π(b^2)ε0) + -q/(4π(a^2)ε0)?
A CONDUCTING shell, right? Spherical, so Gauss' Law applies and the E field outside depends only on the total charge inside the sphere so I think your first thought,
E = (3q-q)/(4πr^2ε0) is correct. Integrating E*dr in from infinity gives V = 2q/(4πr)ε0 (oops, you had r²) and that should be good to radius b. No change going through the conductor. A charge of +q is induced on the inner surface which kills the E field due to the -q at the center (leaving a charge of +2q on the outer surface of the shell). Once r < a, E = (-q)/(4πr^2ε0), the potential change is the integral of this new E going the opposite way so V will get smaller as r gets smaller.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 23 ·
