How can i determine Specific heat capacity of Water cpv if i know all variables
The specific heat capacity of water (cpv) can be determined using the equation: [(mi1 + mi2 + mv)cpv + mg*cpg]dT/dt = H. Given the values dT/dt = 0.05, cpg = 890 J/(kg*K), and H = 300 W, the formula can be rearranged to solve for cpv as follows: cpv = (H/(dT/dt) - mg*cpg) / (mi1 + mi2 + mv). This method requires knowledge of the masses involved (mi1, mi2, mv) and the heat capacity of the gas (cpg) to compute cpv accurately.
  • Understanding of thermodynamics principles
  • Familiarity with specific heat capacity concepts
  • Knowledge of algebraic manipulation of equations
  • Basic understanding of mass and energy transfer
  • Study the principles of thermodynamics and heat transfer
  • Learn about specific heat capacity calculations in different materials
  • Explore the application of the first law of thermodynamics in practical scenarios
  • Investigate the effects of varying mass on heat capacity in experimental setups
Students and professionals in physics, engineering, and environmental science who require a solid understanding of heat capacity calculations and thermodynamic principles.
Firben
If i use this equation:
[(mi1 + mi2 +mv)cpv + mg*cpg]dT/dt = H
mi1 = mass 1
dT/dt = 0.05
cpg = 890 J/(kg*K)
mi2 = mass 2
mv = mass 3
H = 300 W
masses are arbitrary numbers
Its cpv that i should determine
I'm assuming you're having difficulties solving the equation for [itex]cpv[/itex], in that case you need to give it a go and show us what you've done and where you're getting stuck. Your final answer should look like this, see if you can get it.
[tex]cpv = \frac{\frac{H}{\frac{dT}{dt}} - mg cpg}{m_{i1} + m_{i2} + m_v}[/tex]
  • · Replies 16 ·
  • · Replies 17 ·
