Please give me some suggestions about malloc
  • Thread starter Thread starter nenyan
    Suggestions
The discussion centers on memory allocation issues in C programming using the malloc function. The user encounters a memory error when attempting to allocate an array of doubles with N set to 5*10^8 on a Windows 7 system with 8GB of RAM. The problem arises due to exceeding the range of a 32-bit integer, which limits the maximum allocatable memory. A suggested solution is to use a 64-bit compiler to handle larger memory allocations effectively.
  • Understanding of C programming language
  • Familiarity with memory management concepts in C
  • Knowledge of 32-bit vs 64-bit architecture
  • Experience with the malloc and free functions in C
  • Research the differences between 32-bit and 64-bit compilers in C
  • Learn about memory allocation limits in C on different operating systems
  • Explore alternative memory management techniques, such as using dynamic arrays
  • Investigate the use of tools like Valgrind for memory debugging in C
C programmers, software developers working with memory-intensive applications, and anyone troubleshooting memory allocation issues in C on Windows systems.
nenyan
Code:
#include <stdio.h>
#include <stdlib.h>
#define N 250000000
int main()
    int i;
    double *x;
    if(!(x = malloc(N * sizeof(double)) ))
            printf("memory error \n");
free(x);
When N is larger than 2.5*10^8, it appears memory error. I have 8GB memory. The system is Windows7. How to solve this problem. I hope N=5*10^8 at least.
Technology news on Phys.org
A 64-bits compiler will probably help.
As it is you are overrunning the range of a 32-bits integer.
  • · Replies 17 ·
