Energy in two different frames
  • Context: Graduate
  • Thread starter Thread starter Lawrencel2
    Energy Frames
The discussion centers on the concept of energy in different reference frames, specifically regarding a particle with a rest mass of 100 MeV/c² traveling at a velocity of (8/9)¹/² c. In the particle's rest frame, its energy is solely its rest energy of 100 MeV, as it is stationary and has no kinetic energy. The conversation emphasizes that kinetic energy is associated with collisions between energetic particles and that energy measurements can vary based on the observer's motion relative to the particle, highlighting the importance of reference frames in relativistic physics.
  • Understanding of relativistic mass-energy equivalence
  • Familiarity with the concept of reference frames in physics
  • Knowledge of kinetic energy and its relation to particle collisions
  • Basic principles of the Doppler effect in light and energy measurements
  • Study the principles of special relativity, focusing on Lorentz transformations
  • Explore the concept of relativistic energy and momentum
  • Learn about the Doppler effect and its implications in particle physics
  • Investigate the relationship between kinetic energy and work done in particle collisions
Physicists, students of relativity, and anyone interested in understanding energy dynamics in different reference frames, particularly in the context of particle physics.
Lawrencel2
If you have a particle, and you know its rest mass is about 100 Mev/c^2 and in the lab frame you measure it to travel at (8/9)^1/2 c then what is its energy in the rest frame?? Would it be just 100MeV? or 300 MeV due to the relativistic constant? i don't really know how you would reason out the difference in frames? can anyone explain this idea?
In the particle's own rest frame, it's stationary, so its kinetic energy is zero. Therefore, in that frame, its energy is only the rest energy which is 100 MeV.
Keep in mind the so-called kinetic energy "of" a particle is really an energy associated with a collision between energetic particles. Acceleration with respect to a light source, causing a Doppler shift of the light being received, does NOT in anyway mean that the light energy is different relative to the motions of the observer, but rather, the energy measured once the light is received is of the collision between the photon and the observer. The same is true for particle (which in this case is not light). The additional "kinetic energy" supposedly either gained (or lost) by this particle by change of reference frame actually owes physical existence by the work done on the observer in the direction either toward (or away from) that particle, which is what will contribute additional energy to (or reduce the energy of) the collision.
  • · Replies 51 ·
  • · Replies 19 ·
  • · Replies 54 ·
  • · Replies 87 ·
