| New Reply |
Moment of inertia of a solid sphere derivation. |
Share Thread | Thread Tools |
| Dec12-11, 07:51 PM | #1 |
Hello! I'm trying to derive the formula for the moment of inertia of a solid sphere, and I keep running into a strange solution.
I set up the infinitesimally mass of an infinitesimally thin "shell" of the sphere: dm = 4[itex]\rho[/itex][itex]\pi[/itex]r2 dr And then solved for the moment of inertia: I = [itex]\int[/itex]r2dm = [itex]\int[/itex]r2(4[itex]\rho[/itex][itex]\pi[/itex]r2 dr) = 4[itex]\rho[/itex][itex]\pi[/itex][itex]\int[/itex]r4 dr = (4/5)[itex]\rho[/itex][itex]\pi[/itex]r5 And solving for [itex]\rho[/itex] we get the following: [itex]\rho[/itex] = M/((4/3)[itex]\pi[/itex]r3). Substituting that into the previously solved equation for I, I get the following: I = (3/5)Mr3. What am I doing wrong? I know the formula involves a coefficient of 2/5, not 3/5, but I can't find my problem. Thank you in advance! |
| Dec12-11, 08:22 PM | #2 |
oops bad idea, think about adding lots of thin disks together
so dI=(1/2)(r^2)dm=(1/2)(r^2)(rho)dV=1/2(r^4)(rho)(pi)dh then integrate from -R to R, and sub (r^4) as (R^2-h^2)^2 |
| Dec12-11, 08:26 PM | #3 |
Recognitions:
One problem is that you have two different r's in there. The r in dm is the spherical distance of the shell from the origin. The r in the r^2 of the I calculation is supposed to be the distance from the axis of rotation. Revisit finding I for the shell. You'll need to split the shell up into rings.
| Dec12-11, 08:27 PM | #4 |
@6.283...: Well if you integrate both sides of the original equation, you get m = (4/3)*(pi)*(r^3)*(rho), so the volume part is correct I think....
@Dick: Oh, so I treat the first r (let's call the second one R) as a constant in the first line for evaluating the integral? So I just bring out "r" and integrate R^2 dR? |
| Dec12-11, 08:34 PM | #5 |
Recognitions:
| Dec12-11, 08:45 PM | #6 |
yeah haha I think the disk idea is better..I cant type very fast atm, you dont need any angles
| Dec12-11, 09:00 PM | #7 |
Still not sure exactly how to relate R to r. Is it like, r is the distance from the origin of the shell, and R is the radius of the infinitesimally small disk? Can anybody tell me where to go from my mistake above?
| Dec12-11, 09:25 PM | #8 |
The r that you want to calculate should be the distance from the axis of rotation.
Let's say that the axis of ration is the z-axis. Using spherical coordinates, what is the distance from the z-axis in terms of r? |
| Dec12-11, 10:28 PM | #9 |
Wait okay, I think I got it. So, instead of involving spherical coordinates, I just let the radius of the sphere be R, and the distance to the infinitesimally thin disk be z, and then the radius of the disk, y, would be sqrt(R^2 - z^2), and so you integrate [(1/2)*(rho)*(pi)*(y^4) dz] since you're just using the inertia of a disk, right?
Substitute for y, remove the constants and you get I = (1/2)*(rho)*(pi) * (integral<-R, R> of [R^2 - z^2]^2 dz). If you integrate that, you get I = (8/15)*(rho)*(pi)*(R^5). I think that works, because then you substitute in (rho), and you get I = (2/5)MR^2. Did I get lucky, or is that one way to do it? I don't particularly like spherical coordinates, so I try and avoid them whenever possible. :) |
| Dec12-11, 11:00 PM | #10 |
Recognitions:
| New Reply |
| Tags |
| calculus, dynamics, moment, physics, sphere |
| Thread Tools | |
Similar Threads for: Moment of inertia of a solid sphere derivation.
| Moment of inertia of a solid sphere | Classical Physics | 3 | ||
| moment of inertia of solid sphere | General Physics | 6 | ||
| Moment of inertia of solid sphere | Introductory Physics Homework | 10 | ||
| derivation of solid sphere moment of inertia | Introductory Physics Homework | 10 | ||
| Moment of Inertia for a Solid Sphere | Introductory Physics Homework | 2 | ||
