Projectile Motion Question: Pumpkin Falling from a Moving Truck
The discussion revolves around a projectile motion problem involving a pumpkin falling from a moving truck. The truck is traveling at a speed of 20 m/s, and the pumpkin falls from a height of 5 m. Participants are trying to determine how far behind the truck the pumpkin lands when it hits the ground.
  • Participants discuss the independence of horizontal and vertical motion, questioning the time it takes for the pumpkin to fall and its horizontal displacement relative to the truck. Some express confusion about the correct answer being less than 1 m behind the truck despite initial calculations suggesting otherwise.
There is ongoing clarification regarding the relationship between the pumpkin's and truck's movements. Some participants have provided calculations and reasoning, while others are still grappling with the implications of air resistance and the definitions of the problem. A productive direction has emerged, focusing on the relative motion of the pumpkin and the truck.
Participants note that the answer choices are framed in relation to the truck's position, which adds complexity to the interpretation of the problem. There is also mention of air resistance affecting the pumpkin's motion.
moonpearl
Hi, I was wondering if anyone could help me with this question?
A dump truck filled with pumpkins is traveling at 20 m/s when a pumpkin falls off the back and onto
the road, 5 m below. When the pumpkin hits the road, it will be
A) 5 m behind the truck.
B) 20 m behind the truck.
C) 40 m behind the truck.
D) less than 1 m behind the truck.
I used the equation d=(1/2)at^2 to find the time that it took the pumpkin to fall 5m. Then, I assumed that the horizontal velocity of the pumpkin is 20 m/s, so after finding time, I used V=d/t, 20=d/1. I found that the pumpkin should be 20m behind the truck, but the solution to this question is D.
Can anyone tell me why?
Thanks a bunch.
The horizontal motion is independent of the vertical motion. You could figure out the time it takes the pumpkin to fall to the ground, but who cares?
Both pumpkin and truck are traveling at close to the same horizontal speed: 20 m/s. So, in the one second that it takes for the pumpkin to fall, it does travel 20 m -- with respect to the ground. But so does the truck! They move together.
but that *isn't* the answer...the answer given is D. I understand why it would be 20...but that's supposed to be wrong. I'm sorry, I'm just really confused.
Careful... All the answer choices are described with respect to the truck, not the ground. Note that they all say X meters behind the truck. D is correct, since the pumpkin and truck both move together.
Separate it into horizontal and vertical:
Vertical:
vi=0m/s
d=5m
a=g=9.81m/s/s
t=?
d=vit+1/2at^2
d=1/2at^2
5=.5(9.81)t^2
t=1.01s
Use this obtained value for t in the horizontal problem
t=1.01s
vi=20m/s
a=0
d=?
d=vit+.5at^2
d=vit
d=(20)(1.01)=20.2m
EDITED: So this is the distance the object would travel after released. However, if you calculate the distance the truck traveled in 1.01s (=20.2) then you subtract them and this is your answer:
20.2 - 20.2=0m
This is less than 1m, making the answer (D)
P.S. I only showed the work since you said you had obtained 20 already.
thanks for your replies :) i think i finally get it
Hi,
I don't think that kreil's answer is not correct.
If t = 1.01s (not 1s, as the pumpkin takes 1.01s to reach the ground) Then the truck will travel 20.2m .And therefore the pumpkin will land 20.2 - 20.2 = 0 m from the truck.
The reason why the pumpkin lands behind the truck is that that the air slows it down.
And if the truck stops, then the pumpkin will hit the truck, not FALLING BEHIND 20m.
I don't know if my answer is correct. But hope so... :-)
Bye bye,
You're right vietdao, thanks for pointing it out (I edited my post).
