Calculating Force of 29.9kg Barbell Underwater
  • Thread starter Thread starter SnowOwl18
    Underwater
The discussion revolves around calculating the force required to lift a 29.9kg steel barbell underwater, considering the effects of buoyancy. Participants explore the relationship between weight, buoyant force, and the forces exerted by the bodybuilder.
  • Participants discuss the role of buoyant force and its calculation, questioning how to determine the volume of the barbell and its impact on the lifting force required underwater.
Some participants have provided insights into the calculations for buoyant force and its relationship to the force exerted by the bodybuilder. There is an ongoing exploration of the correct approach to find the necessary values and how they interact.
Participants are navigating the complexities of density and volume in relation to different materials (steel vs. water) and are working within the constraints of the problem's parameters without complete information on the volume of the barbell.
SnowOwl18
-----A bodybuilder is holding a 29.9kg steel barbell above her head. How much force would she have to exert if the barbell were lifted underwater?----
Ok...I'm really not sure of this one. I thought maybe the answer was the weight of the barbell (mg) plus the atmospheric pressure at sea level...does anyone know if I'm headed in the right direction? Thanks.
buoyant force
Consider the buoyant force that the water exerts on the barbell. This force acts upwards, making the barbell easier to lift under water.
most equations say that the buoyant force= density of water x volume of object x gravity. but i do not know the volume...i do know that mass= density x volume...but if that is so, couldn't i theoretically just multiply the mass of the barbell by gravity to get the answer?
No. One equation uses the density of water; the other, the density of steel. (But you're getting closer.)
Steel...I should've seen that. Well, what I tried to do was find the volume of steel using what I knew... 29.9kg= 7860kg/m^3 x V ...and for that value I got 0.0038m^3...and so I multiplied that by the density of water and then by gravity to get the buoyant force and got 37.28N, but the program says it's wrong. And I thought I was headed in the right direction...lol. Is there another huge mistake I'm making?
That's the correct value for the buoyant force. So, how does that relate to the force that the bodybuilder needs to exert on the barbell?
Well...the buoyant force is the weight of the displaced water...aha! I have it. You subtract the buoyant force from the force that would normally be exerted above water (mg). Thank you for your help! :D
  • · Replies 24 ·
