Question about integration with inverse trigonometric functions
The discussion focuses on deriving the equations for harmonic simple motion using inverse trigonometric functions. The differential equation governing the motion is given by \(\frac{ds}{dt} = -k^2s\), leading to the velocity equation \(v = \pm k\sqrt{a^2 - s^2}\). The constant \(C\) is justified as \(a^2k^2\) since the velocity is zero when the particle is at its amplitude \(s = a\). The final position equation is established as \(s = a\cos(kt)\), confirming the relationship between position and time in harmonic motion.
  • Understanding of differential equations, specifically \(\frac{ds}{dt} = -k^2s\)
  • Familiarity with inverse trigonometric functions, particularly \(\arccos\)
  • Knowledge of harmonic motion principles and equations
  • Basic calculus skills, including integration techniques
  • Study the derivation of harmonic motion equations in detail
  • Learn about the properties and applications of inverse trigonometric functions
  • Explore the relationship between angular frequency and harmonic motion
  • Investigate the role of constants in differential equations and their physical interpretations
Students studying calculus, particularly those focusing on differential equations and harmonic motion, as well as educators seeking to clarify concepts related to inverse trigonometric functions in physics.
pc2-brazil
I'm self-studying Calculus and would like to ask some doubts about the following question:
If, in t seconds, s is the oriented distance of the particle from the origin and v is the velocity of the particle, then a differential equation for harmonic simple motion is:
[tex]\frac{ds}{dt}=-k^2s[/tex]
where k2 is a proportionality constant.
Since [itex]\frac{dv}{dt}=\frac{dv}{ds}\frac{ds}{dt}=v\frac{dv}{ds}[/itex],
[tex]v\frac{dv}{ds}=-k^2s[/tex]
a) Obtain that [itex]v = \pm\sqrt{a^2-s^2}[/itex]. Note: Take a²k² as the arbitrary integration constant and justify this choice.
b) Taking t = 0 in the instant that v = 0 (s = a), obtain that s = a cos kt.
a)
[tex]\int vdv=\int -k^2sds[/tex]
[tex]\frac{v^2}{2}=-\frac{k^2s^2}{2}+\text{constant}[/tex]
[tex]v^2=-k^2s^2+C[/tex]
[tex]v=\pm\sqrt{C-k^2s^2}[/tex]
[tex]v=\pm\sqrt{a^2k^2-k^2s^2}[/tex]
Using C = a²k²:
[tex]v=\pm k\sqrt{a^2-s^2}[/tex]
I'm not sure how to justify the choice of C as a²k². Is it because the velocity will be 0 for s = a (the amplitude of the motion)?
b)
[tex]\frac{ds}{dt}=\pm k\sqrt{a^2-s^2}[/tex]
[tex]\frac{ds}{\sqrt{a^2-s^2}}=\pm k dt[/tex]
[itex]\arcsin\frac{s}{a} = \pm kt + \bar{c}[/itex] where [itex]a > 0[/itex]
[tex]\frac{\pi}{2} - \arccos\frac{s}{a} = \pm kt + \bar{k}[/tex]
[tex]-\arccos\frac{s}{a} = \pm kt + \bar{k} - \frac{\pi}{2}[/tex]
Replacing [itex]\bar{k} - \frac{\pi}{2}[/itex] by [itex]\bar{c}[/itex]:
[tex]-\arccos\frac{s}{a} = \pm kt + \bar{c}[/tex]
[tex]\arccos\frac{s}{a} = \mp kt - \bar{c}[/tex]
When t = 0, s = a, so:
[tex]\arccos\frac{a}{a} = -\bar{c}[/tex]
[tex]\arccos 1 = -\bar{c}[/tex]
[tex]\bar{c}=0[/tex]
Then:
[tex]\arccos\frac{s}{a} = \pm kt[/tex]
Now the problem is that I'm not sure how to get rid of the ±.
I think that ± is eliminated here because, in the way that the arc-cosine function is defined, its image is from 0 to π (therefore, its image must be positive). Then:
[tex]\frac{s}{a} = \cos kt[/tex]
[tex]s = a\cos kt[/tex]
Thank you in advance.
Cosine is an even function, cos(x)=cos(-x). When you take the cosine of both sides of [itex]\arccos\frac{s}{a} = \pm kt[/itex] it gives the single result [itex]\frac{s}{a} = \cos kt[/itex].
ehild
  • · Replies 17 ·
  • · Replies 22 ·
