Pendulum Amplitude and phase constant
The problem involves a simple pendulum with a specified length and mass, which is released from a certain angle. The focus is on determining the phase constant and amplitude using the given equation for angular displacement.
  • Participants discuss the significance of the symbols used in the equation, particularly the unfamiliar symbol "ζ" and its relation to angular frequency. There are suggestions to find the period of the pendulum first to derive the angular frequency. Questions arise about how to apply the initial conditions to find the phase constant.
The discussion is active, with participants providing insights into the relationship between amplitude and phase constant. Some guidance has been offered regarding the use of initial conditions to find the phase constant, though there is acknowledgment of the complexity due to multiple variables involved.
There is mention of a lack of clarity in the teacher's explanations and the challenge of using unfamiliar symbols in the equations. Participants are navigating these constraints while attempting to understand the problem better.
soccerscholar
A simple pendulum of length 1m with bob mass 125g is pulled 15 degrees to the right and released at t=0.What are the phase constant and amplitude?
θ(t)=Acos(ζt+phi) ---> my teacher gave us a weird symbol that I've never seen before, it has always been ω instead of ζ on classwork and such.
I am just completely lost with how to even start this. My teacher doesn't explain anything, he basically gives us in-class problems that have nothing to do with the homework he assigns. Can someone explain how amplitude and phase constant can be found?
I once had a Japanese prof who ran out of English and Greek letters, so he started using Japanese ones. Don't let it bother you; remember Feynman said the names don't matter.
Why not find the period first? Then you can get the ω easily. And figure out what phi you need to make it fit the angle at time zero.
The weird symbol "ζ" is "zeta", the seventh letter of the Greek alphabet. The actual symbols don't matter - it is their roles that count.
(I once ran out of letters and resorted to geometric shapes.)
The phase is [itex]\phi[/itex]. To find it, consider what the amplitude is at t=0 in your experiment and in the equation.
[itex]\zeta = 1/ 2\pi T[/itex] ... which is, of course, the angular frequency. I figure you can find the period of a pendulum OK?
Wow, it's really that simple? Thanks, I really understand this a lot better.
So to find phi, do I use θ(0)=Acos(phi), plug in the initial angle it was pulled back for the theta0, and solve for phi?
Careful - you have two variables, the phi and the A.
The A is the amplitude. The phi modifies the start value because you may not start time exactly when the swing is at it's maximum displacement.
If the equation was a sign instead of a cosine, phi would be different.
12K
  • · Replies 17 ·
