| New Reply |
Calculate change in height of fluid in a cylinder based on flow out |
Share Thread |
| Dec13-11, 07:36 PM | #1 |
A cylinder with radius five has water in it. The water flows out of the cylinder with a rate of 5π units cubed per minute. At what rate does the height of the fluid in the cylinder change? 2. Relevant equations volume of a cylinder = [itex]πr^{2}h[/itex] 3. The attempt at a solution I know the height of the cylinder is constant. I think using [itex]\int f(t) \mathrm{d} t = \frac{5}{2}πt^{2} + C[/itex] would help me, where [itex]f(t) = 5πt[/itex], or the amount of water released in t minutes. Thanks for any help. |
| Dec14-11, 12:25 AM | #2 |
So you already have that the volume of the water is
[tex] V = \pi r^2h [/tex] And you're given that the rate of loss of water is [itex]\displaystyle 5 units^3min^{-1}[/itex] so you have [tex] \frac{dV}{dt} = 5 [/tex] Now what is [itex]\displaystyle \frac{dV}{dt} [/itex] ? |
| Dec15-11, 09:45 AM | #3 |
So that tells me that the change in volume with respect to time is 5π, no? For example, after t minutes, [itex]5πt[/itex] water would have been released.
| Dec15-11, 10:02 AM | #4 |
"I know the height of the cylinder is constant." But the height of the column of water is not. In fact, it is dh/dt that you are asked to find. The radius is constant. Yes, [itex]V=\pi r^2h[/itex]. So what is dV/dt as a function of dh/dt?
| Dec15-11, 09:39 PM | #5 |
Forgive me if I'm completely wrong, been studying for finals all day and night and it's late here.
From what I've calculated, [itex]\frac{dV}{dt} = 25π\frac{dh}{dt}[/itex]. Thanks for the help. |
| New Reply |
| Tags |
| calculus, geometry, word problem |
Similar discussions for: Calculate change in height of fluid in a cylinder based on flow out
| Calculation of tank height based on flow rate | General Physics | 4 | ||
| Calculating the change in flow rate with varied height. | General Physics | 0 | ||
| Calculate Height Change Help Needed | Introductory Physics Homework | 1 | ||
| Calculate the individual flow rate - based on the pressure drop? | Mechanical Engineering | 0 | ||
| how do I calculate fluid flow? | General Physics | 5 | ||
