Integration of exponential of inverse tangent
The discussion revolves around the integration of an expression involving the exponential of the inverse tangent function. Participants explore methods for solving the integral, including integration by parts and the use of special functions.
  • One participant seeks assistance with the integral I=∫A/[w(a+z^2)^1/2]*exp(zb)*exp[(-i*arctan(z/(a)^1/2)] and mentions difficulty with the arctan component.
  • Another participant suggests that a closed form in terms of elementary functions may not exist and proposes that the solution will involve the special function Ei(z) extended to the complex plane.
  • A participant revises their initial equation to use arctan(z/a) instead of arctan(z/a^1/2) and reformulates the integral, leading to a new expression involving cos(theta) and sin(theta).
  • The same participant further simplifies the integral and expresses it in terms of a new variable u, suggesting a connection to the exponential integral term.
  • Another participant confirms the correctness of the revised approach and identifies the integral in terms of the exponential integral function Ei.
Participants do not reach a consensus on the existence of a closed form for the integral, and multiple approaches and interpretations of the integral remain present throughout the discussion.
Some assumptions about the variables and the nature of the integral are not fully explored, and the discussion includes various transformations and substitutions that may depend on specific conditions.
Elsasw
Hi all, i need help with integration of exponential of inverse tangent, could not find it in table of integrals
the whole equation is
-am trying to integrate by parts but stuck at the arctan part
Thank you.
You won't be able to find a closed form in terms of elementary functions. It looks like the answer will necessarily involve the special function [itex]\mbox{Ei}(z)[/itex], defined for real numbers as
[tex]\mbox{Ei}(x) = \int_{-\infty}^x \frac{e^t}{t},[/tex]
though your integral will require the extension of this function on the complex plane.
Anyways, for your problem, I would use [itex]e^{-i\theta} = \cos\theta - i \sin\theta[/itex]. Since [itex]\theta = \tan^{-1}(z/\sqrt{a})[/itex] you can rewrite the sine and cosine in terms of only z, a, and (z^2+a)^(0.5). The last hint I will give is that the overall denominator you get can be factored (with imaginary roots) to cancel with part of the numerator.
Thank you mute. I redid the initial equations and put the inverse tangent term as arctan (z/a) instead of arctan (z/a^1/2) as earlier.ignore the w as i already factor it out. so now i got
I=∫A/[(z^2+a^2)^1/2]*exp(bz)exp(-i*arctan(z/a)) *dz
=A∫1/[(z^2+a^2)^1/2]*exp(bz)*cos(theta)-i*sin(theta) *dz
where theta=arctan(z/a)
=A∫1/[(z^2+a^2)^1/2]*exp(bz)*(a-i*z)/[(z^2+a^2)^1/2]*dz
finally
I=A∫(1/a+iz)exp(bz)*dz
After this, let u=a+iz
I=-iA*exp(iab)*∫exp(-ibu)/u*du
This is referring the exponential integral term rite. I hope this is what you meant.
Thanks again.
finally
Thanks again.
I haven't checked it carefully, but yes, that looks about right. You can now identify
[tex]\int du~\frac{e^{-ibu}}{u} = \mbox{Ei}(-ibu) + \mbox{const}[/tex]
and put u back in terms of z.
Thanks a lot mute...
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 30 ·
