Use Conservation of Momentum or Conservation of KE for spring problem
The discussion revolves around a collision problem involving two blocks, one of which has a spring attached. The original poster seeks to determine which physical quantities remain the same for both blocks after the collision, specifically questioning the use of conservation of momentum versus conservation of kinetic energy in this context.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the nature of the collision, questioning whether it is elastic and what that implies for kinetic energy and momentum. There is discussion about the differences in mass and velocity of the blocks and how that affects their kinetic energy and momentum post-collision.
The conversation is ongoing, with participants examining various interpretations of the problem. Some have provided insights into the nature of elastic collisions and the implications of conservation laws, while others are clarifying the setup of the problem and the role of the spring.
There is confusion regarding the attachment of the spring to the blocks, with participants noting inconsistencies in the problem statements. This has led to questions about the clarity of the scenario being discussed.
brainyasian
Block A with mass 13kg is moving right on a frictionless table. Block B with mass 1kg is moving left. Block B has a spring on its left side, the side that will hit Block A. THe question is: Which is the same for both after the collision?
1. speed
2. velocity
3. acceleration
4. KE
5. magnitude of momentum
Conservation of momentum
Conservation of energy
I eliminated choices 1-3, but I don't know if you use the conservation of momentum or the conservation of energy for this problem. I know that the collision has to be elastic to use CoE but I know you can always use conservation of momentum. So, which one is the right answer?
An ideal spring will provide a perfectly elastic collision. Sure, the collision will "occur" over some small period of time and distance that is longer than it would be for a pair of infinitely "stiff" blocks, but it will still be elastic.
So you should ask yourself the same question assuming that a perfectly elastic collision just occurred.
But I was pretty sure it was elastic. But wouln't that mean that both KE and momentum are the same?
The totals, yes (conservation laws). But they are asking what is the same for both.
Exactly, so wouldn't both KE and momentum be the same ? But there's only one right answer.
Here's the problem.
No. The blocks will have different KE and momentum. 0.5m1v12 will not equal 0.5 m2v22, and m1v1 will not equal m2v2.
brainyasian said:
Here's the problem.
That is a different problem! The spring connection is permanent in this one. In the problem you posed, the spring was attached only to the second block.
I'm sorry, I mixed up two problems. But in the problem I gave, wouldn't KE and momentum both be the same?
No, the blocks have different masses and different velocities (both before and after the collision).
Conservation laws apply to TOTALS for a given system, not individual elements of the system.
But then velocity and acceleration can't be the same.
Well the velocities probably won't be the same (you can calculate the final velocities if you wish to do the collision math). But why do you say the accelerations can't be the same? What forces are acting on the blocks AFTER the collision?
isn't this the same principle as two people on a frictionless surface pushing each other apart? I still think it's momentum. Can you please explain using formulas why it's acceleration? I would think that acceleration for the larger mass would be less.
AFTER the collision is complete, what are the forces acting on each block?
just the force of the spring. I'm now wondering if this has to do with Center of Mass. We haven't covered that yet though, so I don't know.
:confused: I thought that the spring was only connected to block B? The problem didn't say anything about the spring sticking to block A during the collision.
Are you mixing up two different problems again?
Oh, I'm sorry. To clear it all up, it's all in the image. it's stuck to both blocks and when the blocks are pulled apart, they contract
You have two separate threads (with the same title) with two different problem statements. The problems statements are not the same. The original post in this thread stated that the spring was connected only to block B. Is this a separate problem or are you running two threads for the same problem?
We cannot help you solve a problem unless the problem statement is clear and consistent. Please choose one scenario per thread and stick to it, or choose one thread and abandon the other.
Very well, go to this link for the problem. https://www.physicsforums.com/showthread.php?p=3669539#post3669539
  • · Replies 17 ·
  • · Replies 18 ·
