Is it possible to extract the diagonal elements of a matrix into a vector?
It is possible to extract the diagonal elements of a matrix into a vector using only matrix multiplication, as discussed in the forum. The method involves a sequence of matrix multiplies and adds, focusing on isolating each diagonal element into a 1x1 matrix and then expanding it into the correct position in a vector. This approach requires careful manipulation of matrix dimensions, potentially involving matrices of order N² or N³, depending on the size of the original matrix.
  • Understanding of matrix multiplication principles
  • Familiarity with MATLAB programming
  • Knowledge of matrix dimensions and their manipulation
  • Concept of vector representation in linear algebra
  • Research techniques for matrix multiplication in MATLAB
  • Explore linear algebra concepts related to diagonal matrices
  • Learn about vectorization techniques in MATLAB
  • Investigate advanced matrix operations and their applications
Mathematicians, MATLAB programmers, and anyone interested in advanced matrix manipulation techniques.
7Deuce
Is it possible to extract the diagonal elements of a matrix into a vector??
Is it possible to extract the diagonal elements of a matrix into a vector USING ONLY MATRIX MULTIPLICATION? So no element by element multiplication, and no diag commands.
(This will eventually be implemented in MATLAB, but I am required to only use matrix multiplication, so no commands)
Is it even possible?
Thanks in advance.
You can do it with a sequence of matrix multiplies and adds.
Think about how to get one diagonal element into a 1x1 matrix, and then how to "expand" the 1x1 matrix into the right place in a vector. Repeat and add...
Possibly you combine all those steps part of a bigger matrix multiply operation (I'm speculating here) If the given matrix is order N, you might need matrices with dimensions of N2 or even N3...
  • · Replies 33 ·
