How Long Can the Stick Be to Fit Horizontally Through the Chamber?
  • Context: Graduate
  • Thread starter Thread starter georg gill
    Derivation Length
The discussion revolves around determining the maximum length of a stick that can be carried horizontally through a hallway with a height of 1 meter and a chamber with a width of 8 meters. Participants explore the geometric implications and constraints of the problem, including the relationship between the stick's length and the angles involved.
  • One participant attempts to derive the length of the stick using trigonometric relationships, specifically focusing on the hypotenuse and its maximum value.
  • Another participant questions the clarity of the original question, asking whether the stick length is to be determined for a specific angle θ.
  • A clarification is provided that the stick must fit horizontally in the hallway and chamber, with specific dimensions given.
  • One participant suggests that if there are no vertical constraints, the stick could theoretically be infinitely long if placed vertically, indicating a need for further constraints.
  • Another participant reiterates the problem's constraints, emphasizing the horizontal carrying of the stick and questioning the maximum possible length that can be maneuvered from the chamber to the hallway.
  • A different approach is proposed involving setting up a function related to the height of a ladder, suggesting differentiation to find maximum height, which could relate to the stick's length.
Participants express uncertainty regarding the problem's constraints and the specifics of the question. There is no consensus on the approach to take or the interpretation of the problem.
Participants note potential ambiguities in the problem statement, particularly regarding the assumptions about vertical constraints and the interpretation of the stick's orientation.
georg gill
1052217.jpe
one want to find the length of the two hypotenuses of the figure
Here is what I did. I looked at the small first with hypotenus unknown and adjacent=1 and the other cathetus unknown. Then i wanted to find max value of the smallest hypotenus.
[tex]tan\theta=\frac{1}{a}[/tex][tex]a=\frac{1}{tan\theta}[/tex] Smallest hypotenus=sh
[tex]sh^2=1+\frac{1}{tan^2\theta}[/tex]
i took derivative to find max value
[tex]sh=\sqrt{1+cot^2\theta}[/tex]
[tex]\frac{d}{dx}sh=\frac{1}{\sqrt{1+cot^2\theta}} \cdot \frac{coth\theta}{sin^2\theta}[/tex]
but this is equal to zero when [tex]\theta=\frac{\pi}{2}[/tex] whoch gives sh=1which is obviously wrong since adjacent cathetus=1
What is wrong?
Your question is confusing. Do you want the stick length for a given θ or something else? It is not clear at all.
sorry. One want to find how long the stick could be and still fit in in the hallway with height 1 and chamber with width 8. So another way to try to describe problem, how long the stick could be and still fit in the drawing
If there is no limit on the vertical (in the picture) side of the chamber, you can place the stick vertically and it will be infinite in length. There must be some further constraint in the problem.
I am not sure. It says it is being carried horizontally in the assignment text. This is word by word translation:
You are going to carry a stick from a one meter high hallway into a chamber that has eight meters in width. The stick is carried horizontally and we assume that its thickness is infinite small. How long could the stick be maximally?
This might be hard to describe online but I'll give it a go. I'd set up a function to give the height of the ladder as a function of the height of the bottom of the ladder, set the zero point as the length of the ladder minus 1m from the top of the hallway. Set it up so that the bottom of the ladder sits against the right wall and intersects the corner. Differentiate the function and you can find the maximum height above this zero point, solve this for the max height being the length of the ladder.
Alternatively make the function dependent on the angle theta if that seems simpler to you.
Is this the question? What is the longest possible stick that can be moved from the chamber to the hall?
