Spacecraft Question: How Fast to Travel for 2 Days on Earth?
  • Thread starter Thread starter CollectiveRocker
    Spaceship
The discussion revolves around a relativistic physics problem concerning time dilation, specifically how fast a spaceship must travel for one day on the spacecraft to equal two days on Earth. Participants are exploring the implications of the relativistic factor gamma (γ) in this context.
  • Participants are attempting to apply the concept of time dilation using the relationship between Earth time and spaceship time. Questions arise regarding the correct formulation of gamma and its implications for calculating velocity. There is also a discussion about the validity of using approximations versus the full relativistic equation.
The conversation is active, with participants offering various mathematical approaches and questioning each other's reasoning. Some guidance has been provided regarding the correct use of the gamma factor, and there is an acknowledgment of the need to avoid incorrect assumptions that could lead to non-physical results.
Participants are navigating the complexities of relativistic equations and the constraints of the problem, including the need to avoid speeds exceeding the speed of light. There is also a focus on ensuring the correct application of formulas without oversimplification.
CollectiveRocker
How fast must a spaceship be traveling relative for one day on the spacecraft to equal 2 days on Earth? I'm pretty sure that t(0) = 172,800 seconds, and t = 86,000 seconds. Do I just need to use ∆t = t – t(0), simplify that to t = γt(0), and then since γ = 1+ (1/2)(v^2)/(c^2); take the resulting equation and just resolve for v?
If I remember correctly, you will want to use the relativistic equation for gamma and not the approximation for speeds much lower than the speed of light. So,
gamma = 1/(sqrt(1-(v^2/c^2))) Otherwise, using the aproximation will yeild a speed faster than the speed of light which is not possible.
I'm ending up with v = sqrt{(((t(0)^2)(c^2))/(∆t^2))-c^2} Can someone please check my math?
Close, it may be easier to notice that gamma = (earth time) / (spaceship time)
So, gamma = 2 in your case. Should be easy from here . . .
How does gamma equal Earth time/ spaceship time or 2? Is this just though simplification?
So I can just set gamma equal to 2, and solve for v!
Yes, that should do the trick.
Thanks a bunch Olaf.
If gamma =2, then 2 = 1/(1+(v^2)/(c^2)), thus leaving you with a negative value when you simplify for v.
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 20 ·
