Dropping from 4 times the height, how much longer does it take?
  • Thread starter Thread starter Kaldanis
    Height
The discussion revolves around a physics problem related to free fall and the time it takes for an object to hit the ground when dropped from different heights. The original poster seeks clarification on how the time of fall changes when the height is quadrupled.
  • Participants discuss the use of kinematic equations, particularly the equation for displacement in uniformly accelerated motion. There is a focus on the relationship between height and time of fall, with some participants questioning their recollection of previous discussions and solutions.
Several participants have expressed their thoughts on the problem, with some suggesting that the time should change by a factor of 2 when the height is increased by a factor of 4. Others are reflecting on their past learning experiences and the potential for confusion regarding the presence of a square root in the answer.
Participants mention a previous class discussion on a similar problem, indicating that there may be variations in the problems encountered. There is also mention of an upcoming exam and the use of formula sheets, which may influence how participants prepare for similar questions.
Kaldanis
We solved this in class 4 months ago but I just can't remember the solution, or even where to start. I remember rearranging an equation. If an object is dropped from a height and it takes T seconds to hit the ground, how long will it take if dropped from four times the height?
Possible answers:
A. T seconds.
B. √2 T seconds.
C. 2T seconds.
D. 2 √2 T seconds.
E. 4T seconds.
Can anyone give me a hint without giving the answer?
We aren't supposed to help until we see an attempt but just this once I can't resist.
The approach to any problem is to first realize what is going on and write equations that apply to it. In this case, accelerated motion is going on. Can you write equations that apply?
Is it by rearranging s= ut + .5at2?
Yes, and of course, the initial velocity u is zero.
I keep getting the answer as 2T, is that right? When we did it months ago I'm almost positive it had a root2 in the answer
Sure that's right. If the displacement changes by a factor 4, T changes by a factor of 2. You might be thinking of a different problem.
I must be, that's the only thing that was throwing me off since I first saw the question. I thought I remembered a root2 in there so I was doubting the obvious answer of 2T! Anyway, thank you. :)
Yes, 2T is correct.
When the problem was done earlier, in class, was it exactly the same, or just similar. After all, 2=√4 .
SammyS said:
Yes, 2T is correct.
That's true, but for some reason √2 was stuck in my head. At least I know now for incase it comes up in the exam in January, because I would have doubted myself and picked one of the √2 answers.
When you do the exam in January, are you allowed to take in a self-prepared "formula sheet" or page of notes?
We are given a formula sheet but I'm not sure if we'e allowed to add anything to it. I planned on finding that out when we go back. Luckily it gives the equations I have the hardest time remembering or being able to prove to myself. I wish we were allowed to take in a page of notes for Algebra... not looking forward to that!
  • · Replies 38 ·
  • · Replies 25 ·
