Tangent line approximation with sinx/x + siny/y = C
The problem involves using the tangent line approximation to estimate the y-coordinate of a point on the curve defined by the equation sinx/x + siny/y = C, given a specific x-coordinate. The context is within calculus, focusing on differentiation and approximation techniques.
  • Participants discuss the differentiation of the given equation and the application of the tangent line approximation. There are attempts to simplify expressions and derive the derivative y' at the specified point. Questions arise regarding the correctness of the derivative calculations and the application of the tangent line approximation.
Some participants have provided guidance on the differentiation process and have noted errors in previous calculations. There is ongoing exploration of the derivative's value at the given point, with differing results being shared. The discussion reflects a collaborative effort to clarify the correct approach to the problem.
Participants are working under the constraints of homework guidelines that emphasize the use of calculus methods rather than algebraic solutions. There are indications of confusion regarding the signs and values of derivatives, as well as the implications of the tangent line approximation.
franklingroye
Suppose the point (pi/3, pi/4) is on the curve sinx/x + siny/y = C, where C is a constant. Use the tangent line approximation to find the y-coordinate of the point on the curve with x-coordinate pi/3 + pi/180.
TLA: f(a) + f'(a)(x-a)
Where a is the known value of x and x is the value you are estimating the output of.
Before differentiating I figured that I could replace siny/y with siny * y^-1.
I got here:
((x)(cosx) – sinx)/x2 + y’(siny)(-y-2) + cosy(y’)(y-1) = 0
which I THINK can be simplified to:
((x)(cosx) – sinx)/x2 + y’(siny*-y-2 + cosy*y-1)
dunno where to go with it from there D:
MAYBE, here's what I attempted:
((x)(cosx) - sinx)/x2 = -y’(siny*-y-2 + cosy*y-1)
-((((x)(cosx) - sinx)/x2)/(siny*-y-2 + cosy*y-1)) = y'
But that doesn't seem right. The question gave the curve sinx/x + siny/y = C with the point (pi/3, pi/4) given. Substituting I got C = 1.7273097. However using tangent line approximation with the derivative I calculated I got the y coordinate there to be 418.879:
f(a) + f’(a)(x – a)
f(π/3) + f’(π/3)(π/180)
1.7273097 + 24000(π/180)
I know I could just do normal algebra for this instead of calculus but the instructions say to use tangent line approximation so I think I'd get points docked. I am pretty sure though the answer I'm after is y = 0.905801 based on just solving for the values using C = 1.7273097 and x = pi/3 + pi/180... pretty far off from 418.879.
Someone please help, I've got no idea what to do here.
If it helps get the help any quicker I don't really care about a pretty, formatted answer... I really need help on this soon so whatever helps.
I got here:
f(a) + f’(a)(x – a)
Hello franklingroye. Welcome to PF.
I agree with your result for C.
What is your result for y' when x = π/3 and y = π/4 ?
I got y' ≈ -0.000876215 there.
The way you are using the tangent line approximation is wrong.
y = f(x), so f(π/3) = π/4
Goodness, I can't believe I managed to mess up with f(x) haha.
I'm not sure how to really get y' out of this is the issue I am having. If I leave it as-is instead of changing it to siny*y-1:
((x)(cosx) – sinx)/x2 + y'((y)(cosx) – siny)/y2
((x)(cosx) – sinx)/x2 = -y'((y)(cosy) – siny)/y2
[((x)(cosx) – sinx)/x2]/(y)(cosy) – siny)/y2 = -y'
-[((x)(cosx) – sinx)/x2]/(y)(cosy) – siny)/y2 = y'
-((((pi/3)(cos(pi/3)) - sin(pi/3))/(pi/3)^2)/((((pi/4))(cos(pi/4)) - sin(pi/4))/(pi/4)^2)) = -1.269321
I've got no idea where I'm screwing up
I tested the TLA equation with y' = -0.000876215 and it's correct but now I just need to figure out how to get there. :\ I'm obviously messing up somewhere in the differentiation process.
I checked your work to here and it looked good.
((x)(cosx) - sinx)/x2 = -y’(siny*(-y-2) + cosy*y-1)​
Solving that for y', I got:
[itex]\displaystyle y'=-\frac{y^2\left(x\cos(x)-\sin(x)\right)}{x^2\left(y\cos(y)-\sin(y)\right)}[/itex]​
And I see that I had a sign error when I calculated y' at the given point.
It should have been y' ≈ 0.00728974
(Yes, it's positive.)
I don't get what's going on here, using my calculator to simply plug in pi/3 and pi/4 for x/y in your derivative I end up with 0.15257. ,-,
Check parentheses.
After rechecking my algebra, I now get y' ≈ -1.26932145 ; back to a negative, and it should be negative when considering the values of x & y used in
For the values of x & y used here, cos(x)=1/2, sin(x)=(√3)/2, cos(y)=sin(y)=(√2)/2 .
