Is my linear algebra book's definition of Euclidean space correct?
  • Context: Undergrad
  • Thread starter Thread starter quasar987
    Definition Space
The discussion revolves around the definition of Euclidean space as presented in a linear algebra book, specifically comparing it to other definitions found online. Participants explore the implications of the definitions regarding scalar products and their existence within finite-dimensional vector spaces.
  • One participant questions whether the definition from their linear algebra book is equivalent to another formulation regarding scalar products and Euclidean spaces.
  • Another participant expresses confusion over the equivalence of the two definitions, stating they see no difference.
  • A different participant raises concerns about the ambiguity in the definitions, suggesting that a scalar product must be defined for a space to be considered Euclidean.
  • One participant mentions the common misuse of notation, asserting that a Euclidean space possesses a Euclidean norm or inner product, but it is not necessary to use the inner product explicitly.
  • Another participant explains that in finite-dimensional vector spaces, all inner products are equivalent to a dot product defined by a basis, leading to the conclusion that every finite-dimensional vector space can be considered Euclidean.
  • Several participants assert that every finite-dimensional vector space over the real numbers is indeed Euclidean.
Participants express differing views on the definitions of Euclidean space and the conditions under which a vector space qualifies as such. There is no consensus on the interpretation of the definitions, and the discussion remains unresolved.
Participants highlight potential ambiguities in the definitions, particularly regarding the necessity of a defined scalar product versus the potential for one to exist. The discussion reflects varying interpretations of these concepts.
quasar987
My linear algebra book seems to give a different definition than Mathworld.com so I'll state it.
A scalar product over a vectorial space V is a vectorial real function that to every pair of vectors u, v, associates a real number noted (u|v) satisfying the 4 axioms...
1.
2.
3.
4.
A vectorial space of finite dimension with a scalar product is called a euclidean space.
My question is the following: I don't like how that definition sounds. Is it equivalent to: "Let V be a vectorial space of finite dimension. If there exists a scalar product function over V, then V is called a euclidean space." ?
P.S. does anyone knows a good website that teaches about diagonalisation of hermitian matrixes?
I honestly don't understand your question.
You are asking if
"A vectorial space of finite dimension with a scalar product is called a euclidean space."
and "Let V be a vectorial space of finite dimension. If there exists a scalar product function over V, then V is called a euclidean space."
are equivalent. I don't see any difference at all!
Thanks for answering my question. :smile:
I found the definitious ambigouous because for a scalar product function to exist, you have to define it first. So according to their definition, a vectorial space with no defined scalar product function is not a euclidian space. But as soon as you do define one, it becomes a euclidean space. My definition says: if a vectorial space is such that a scalar product function CAN be defined (i.e. "potentially"), then it is a euclidean space. That's how I saw it.
I'm kind of realising my definition is no better they theirs now... so let me reformulate my question: "What does the definition says?" Does it say that if there is a defined scalar product function over V then V is a euclidean space, or does it say that if a scalar product function over V can be defined, then V is a euclidean space?
You're just coming across common abuse of notations. A euclidean space is one possessing a euclidean norm/inner product. However you do not *have* to use the inner product. R^2 is eulicdean whether or not you use the inner product.
Ah! now I see what the difference is. In a finite dimensional vector space you can show that every possible inner product is equivalent to a "dot product" defined using a particular basis. (That is, given a basis, to find the "dot product" of u and v, write each as a linear combination of the basis vectors:u= a1e1+ a2e2+... , v= b1e1+ b2e2+... . The "dot product" is a1b1+ a2b2+ ... . The "Gram-Schmidt" orthogonalization process essentiall show that, given any inner product, there exist a basis so that inner product is given by the basis.) I.e. all inner products are equivalent so it really doesn't matter which you use. Of course, every finite dimensional vector space can be given an inner product so, in that sense, every finite dimensional vector space is Euclidean!
Every finite dimensional vector space over R is Euclidean.
  • · Replies 18 ·
  • · Replies 23 ·
