Why is an Electric Current Necessary to Measure the Casimir Effect?
The necessity of an electric current in measuring the Casimir Effect is highlighted through discussions on experimental setups involving two parallel conducting plates. It is established that the induced electric current generates a magnetic field, which can influence the behavior of the plates and introduce external noise factors. Recent experiments, such as those referenced from MIT, consistently show this electric current's presence, raising concerns about its impact on the accuracy of the measurements. The discussion emphasizes minimizing external forces to enhance the reliability of Casimir Effect measurements.
  • Understanding of the Casimir Effect and its experimental setup.
  • Knowledge of electromagnetic theory, particularly the influence of electric currents on magnetic fields.
  • Familiarity with vacuum technology and its importance in experimental physics.
  • Basic principles of noise reduction in experimental measurements.
  • Research the role of electric currents in electromagnetic fields and their effects on experimental results.
  • Study advanced techniques for minimizing external noise in precision measurements.
  • Explore the latest methodologies in Casimir Effect experiments, focusing on vacuum conditions.
  • Investigate the implications of temperature variations on experimental outcomes in physics.
Physicists, experimental researchers, and students interested in quantum field theory and precision measurement techniques related to the Casimir Effect.
philipp2020
Hi
For measuring the casimir effect in a experiment, two conducting plates are set up parallel to each other. As far as I know, in all experiments so far there was always a small electric current induced in both plates.
So my question is: Why is this electric current necessary in such an experiment?
Thank you for an answer.
Philipp
As I didnt get any answers to my last post I would like to clarify my question in some
second post.
The main thing I want to focus on is, that there are so many external forces induced into the experiment, with which it becomes difficult to say, if there is Casimir Effect or not, or if it is corresponding with other factors like heat or a magnetic field. Of course I know that you can cancel out the external forces by estimating their noise effect, but wouldn't it be better to bring it as few as possible external forces in the first place?
In my opinion, for measuring the Casimir Effect there are basically only 2 things necassary. Two plates and a container for creating a vacuum. Any other things implemented into the experiment could create some external "noise".
Now when you look at recent experiments for the Casimir Effect like for example here: http://www.mit.edu/~kardar/research/seminars/Casimir/PRL-Lamoreaux.pdf
There is always a electric current inside the conducting plates. An this creates a magnetic field which can influence the plates behaviour. Furthermore in other recent experiments a temperature change on the surface on the plates was induces, which changes the pressure between the plates.
  • · Replies 46 ·
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 46 ·
