DIY Backyard ZIP-line strength question
  • Context: Construction
  • Thread starter Thread starter Jon Z
    Diy Strength
The discussion revolves around the construction of a DIY backyard zip line, focusing on the structural integrity and safety of the setup. Participants explore various aspects such as pole depth, diameter, cable size, and the necessity of guy wires, while considering the potential risks involved.
  • One participant describes their zip line design, including a 21 ft steel pole and a total length of 175 ft, and poses several questions regarding the pole's depth and diameter, cable size, and the need for guy wires.
  • Another participant expresses caution, stating that they will not provide advice due to the potential for injury and the uncertainty of the tree's stability as an anchor.
  • A different participant highlights the mechanical principles involved, noting that the vertical load on the pole may not be the primary concern, but rather the leverage created by the design, suggesting that guide wires are typically used for stability in similar structures.
Participants do not reach a consensus on the safety and engineering requirements for the zip line. There are differing opinions on the necessity of guy wires and the adequacy of the proposed pole dimensions.
Participants acknowledge the risks associated with constructing a zip line and the importance of site inspection, but do not resolve the technical questions posed regarding pole specifications and cable requirements.
Jon Z
I am building a DIY backyard zip line - total length is 175 ft, starting anchor is a steel pole (6 inch diameter) - 21 ft long, I plan to bury in lots of cement about 4 ft deep - cable will be attached near the top, no guy wires planned, I will "board" the seat on a tree fort near the top of the cable, the lower anchor will be a solid tree - I will anchor it near ground level
by various websites and my own research - every 100 ft you need 6 ft elevation change, and also 2 ft slag for every 100 ft of line, my starting height is about 9 ft platform/tree fort, but the cable will be around 15 ft high
Dont worry, I won't be hitting the tree to stop - I have grass in front of the anchor tree, and can attach a bungey system to slow down and stop
Questions::::: how deep to bury the pole?? how big diameter of pole?? what about 4 inch diameter?? do I need guy-wires to support anchor pole? how big of cable size?? I am about 200 lbs, children are lighter. Can it support me??
I won't give you any advice on this subject for obvious injurious events that could occur if advice is misinterpreted or ill advised by not inspecting the site. Also, you mention solid tree as an anchor but you have no way of knowing how secure the tree actually is.
Generally speaking the vertical load on the pole will not be your problem. You are creating a giant leaver arm. Based on your description you are applying a load to a 21 foot side which needs to be countered by the 4 foot side in the ground. You can easily see how any force you apply to the top will be greatly amplified at the bottom. This is why telephone poles which go more than 4 feet deep always have guide wires to prevent torquing the pole excessively. For something like this I think you should always over engineer it.
Sorry Jon, we don't give advice here for dangerous undertakings. Thread is closed.
  • · Replies 17 ·
12K
10K
  • · Replies 30 ·
