Is the Moon's Orbit Influenced by Earth's Warped Space and Tidal Friction?
  • Context: Undergrad
  • Thread starter Thread starter a.alexandra
    Fall Moon
The discussion revolves around the nature of the Moon's orbit around the Earth, specifically exploring whether this orbit is influenced by the warping of space due to Earth's mass and the effects of tidal friction. Participants examine concepts related to gravitational forces, centripetal acceleration, and the long-term dynamics of the Earth-Moon system.
  • Some participants propose that the Moon's orbit is a result of warped space caused by Earth's mass.
  • Others argue that the Moon's velocity allows it to balance gravitational pull, suggesting it will eventually fall into the Earth, though this understanding is noted as potentially incorrect.
  • A participant presents a thought experiment illustrating how an object can "fall" around a planet, emphasizing that the Moon is in a state of continuous free fall.
  • Some contributions mention that the Moon is receding from the Earth due to tidal friction, which also affects Earth's rotation.
  • There are conflicting views on whether the Moon could eventually escape Earth's orbit, with some suggesting it could take billions of years, while others assert that the process is not runaway and involves complex dynamics.
  • A later reply introduces the idea that the Moon's distance from Earth is influenced by various factors, including tidal interactions with the Sun and chaotic gravitational effects from other planets.
  • One participant reflects on the nature of gravity as described by Einstein, suggesting that from the Moon's perspective, it travels in a straight line at constant velocity.
Participants express multiple competing views regarding the Moon's long-term fate and the nature of its orbit. There is no consensus on whether the Moon will eventually fall into Earth or escape its orbit, and the discussion remains unresolved on these points.
Participants note that the dynamics of the Earth-Moon system are complex and influenced by various factors, including tidal forces and gravitational interactions with other celestial bodies. The discussion highlights the subtleties involved in understanding orbital mechanics and gravitational interactions.
a.alexandra
I understand that the moon doesn't fall down because it is in an orbit around the Earth. Is this orbit created by warped space due to the mass of the earth?
Astronomy news on Phys.org
The velocity of the moon allows it to overcome (well, not completely overcome) the gravitational pull towards the earth. The gravitational pull itself is a centripetal acceleration (take a look at any circular motion physics problem). Eventually it will fall into the earth, just like we will eventually fall into the sun. At least, that's my understanding, which could be wrong.
Edit:
A quick google yields that the moon is a few cm further from the Earth each year, indicating that the velocity is exceeding the centripetal (gravity), and thus, over time, the moon should leave Earth instead of crashing into it.
Why is the velocity overcoming the centripetal force caused by gravity? Shouldn't it be vice versa, that the velocity is slowing down over time?
let's do a little though experiment. (let's also ignore air resistance since it should be negligible in space)
first, imagine standing on a hill and dropping a rock. it should fall straight down, no surprises.
now, imagine throwing it forward. it no longer falls straight down, it goes forward and curves down.
now, imagine throwing the rock even faster. the rock goes further. if you keep throwing the rock faster, it keeps going further.
on an infinite, flat world we could do this forever with greater speeds/distances. the earth, however, is curved.
if we zoom out some on our experiment so we can actually see the curvature of the earth, and we continue throwing our rock farther, it starts going farther and farther around the planet.
now, imagine throwing the rock so fast that it goes all the way around the Earth back to you. at this point it should be right where you first threw it and have the same velocity it initially had. that means it will continue around again... and again, and again, and again, etc.
this is essentially what orbit is. the object moves so fast that it falls around the planet.edit: so, in fact, the moon does fall down, it just has such a huge velocity in a different direction that the direction of the gravitational force on it (and therefore where "down" is) changes really fast as well.
And a little pic to go with the explanation...
http://csep10.phys.utk.edu/astr161/lect/history/cannonS.jpg
Edit:
Thanks!
This makes much more sense now,
a.alexandra said:
Thanks!
Actually, that's the part that's inaccurate. The moon will neither fall into Earth nor escape from it.
These effects are not unstable i.e. the fact that it's moving away does not mean it will just continue to move away. The Moon's distance from Earth is fraught with subtleties having to do with rotational rates and tides. The upshot is that the distance has changed over very long periods but it is not a runaway process.
Actually, the moon probably can potentially escape Earth orbit, it will just take billions of years longer than for the sun to go red giant. All bets are off when that happens.
One could argue that the moon does fall down, it just keeps missing.
Perhaps we should rename Luna to Arthur Dent?
If the Sun, Earth and Moon remained as they are, the Earth's oceans remaining much the same, then the Earth will slow until it matches the Moon's orbital period and the Moon will recede to match the net angular momentum of the system. This state is reached when the Earth's day is 48.5 times the present day and the Moon is at a radius of 552,000 km. However the tidal braking from the Sun still occurs - it's 1/3 the Moon's tidal effect on the Earth and will be much stronger relatively as the Moon backs away. Since the Sun is still slowing the Earth down, eventually the Earth will be turning slower than the Moon and create a net drag on the Moon, causing it to begin a slow approach to the Earth. After about 15 billion years the two will be so close, that the Moon will break up into a ring of debris.
However the Earth, Sun and Moon are not alone. The other planets jostle the three with their gravity, introducing chaotic behaviour into their orbital evolution. Mercury especially could go wandering into the path of the other planets. Thus the Moon might escape, but not via tidal evolution alone.
Darn! I was about to make that reference myself!:-p
Thank you all, what great responses. I guess this would clarify my confusion (?) a bit: The work expended due to a Force active over a distance is described as W= ∫F°dL. So a force acting on an object over a certain length L is W. It seems that this doesn't apply with the force of Gravity because there is no real Work involved in the moon rotating around the Earth (if you discount the friction due to tides, which was an excellent point).
I think the answer to my question has to do with what Einstein said about gravity: that it is not a force per se, but a curve in Space-time, and it takes Relativity to explain it fully. From what I gather: from the perspective of the moon, it is really traveling in a straight line at a constant velocity (weird). Therefore Newton's first law of motion would apply and it will go on traveling at the same velocity for eternity (in the absence of another force). It just wigs me out to think of this.
Chronos said:
JPL gives a pedagogical presentation on orbits at http://www2.jpl.nasa.gov/basics/bsf3-4.php. The moon is slowly receeding from Earth due to tidal friction, which is also slowing the rotation of earth.
The tidal friction thing is interesting. Would tidal friction not decrease during periods of heavy glaciation? If this were to be the case would the moons regression from Earth not slow down, cease or even reverse? Just a thought.
:smile::smile::smile:
It is the tidal effects on the solid Earth that have the major effect, not just the effects on the oceans.
  • · Replies 41 ·
  • · Replies 19 ·
