Spot Size on Moon from Earth Laser Beam
  • Thread starter Thread starter nannygreen
The discussion focuses on calculating the spot size of a laser beam directed at the Moon from Earth, which is 380,000 km away. The beam diverges at an angle of 1.8 x 10-5 radians, leading to a calculated spot size of approximately 391.56 km on the lunar surface. The formula used includes the angular diameter equation: Angular diameter = Spot size / Distance, and the conversion of radians to degrees is necessary for accurate calculations. The Moon's radius of 1738.1 km is noted, but its curvature does not significantly affect the outcome for this problem.
  • Understanding of basic trigonometry and angular measurements
  • Familiarity with the concept of laser beam divergence
  • Knowledge of the formula for calculating arc length
  • Ability to convert between radians and degrees
  • Research the effects of laser beam divergence on long-distance targeting
  • Explore advanced trigonometric applications in astronomy
  • Learn about the physics of light propagation in space
  • Investigate the impact of lunar surface characteristics on laser measurements
Astronomers, physicists, engineers working with laser technology, and students studying optics and astronomy will benefit from this discussion.
nannygreen
I need some help on how to start this problem and I think I can work it out.
A laser beam is directed at the moon 380,000 km from earth. The beam diverges at an angle of 1.8 x 10-5 rad. How large a spot will it make on the moon?
That would be you equation for finding the length of an arc.
[tex]s=r\theta[/tex]
Technically, that gives you the diameter on a flat moon.
You'd then have to figure out how big of an angle that is based on the Moon's radius and use your equation of the length of an arc once again. Considering the size of your spot as compared to the radius of the Moon (1738.1 km), it's not worth it (which is why the radius of the moon wasn't given). For the number of significant digits given, accounting for the curvature of the Moon winds up being the same as for a flat moon.
To solve this problem, we can use the formula for angular diameter:
First, we need to convert the given angle in radians to degrees:
1.8 x 10^-5 rad = 1.8 x 10^-5 x (180/π)° = 0.0010324°
Next, we can plug in the values into the formula:
0.0010324° = Spot size / 380,000 km
Solving for the spot size, we get:
Spot size = 0.0010324° x 380,000 km = 391.56 km
Therefore, the spot size on the moon from the earth laser beam will be approximately 391.56 km.
  • · Replies 21 ·
  • · Replies 40 ·
