| New Reply |
Relative Motion Leads To Impossibilities (or so it seems to me... can you help?) |
Share Thread | Thread Tools |
| Dec25-11, 12:29 AM | #1 |
I have a couple questions about relative motion, since I've been reading everywhere that motion is relative...
(Feel free to point me to other threads that answer these questions if there are any - I searched and couldn't easily find any) QUESTION #1 So if I'm standing still, and someone travels away from me at almost the speed of light, noticeably less time will pass for him than for me, right? But his motion and speed are being measured relative to me, right? And that means that I am also traveling away from him at almost the speed of light. So time should slow down for me also. But it doesn't. How can that be explained? QUESTION #2 Let's say that me and 2 friend are hanging out in space. Friend #1 gets on his rocketship and zooms off to my right at 75% of the speed of light. Friend #2 gets in his rocketship and zooms off to my left at 75% of the speed of light. Relative to me, both friends are traveling at 75% of the speed of light. But relative to each other they are traveling at 150% of the speed of light. But nothing can travel faster than light. So something impossible is happening. How can that be explained? Thanks in advance for any answers. |
| Dec25-11, 12:48 AM | #2 |
Question one:
Yes. You observe your friend's time ticking by more slowly and he observes your time ticking by more slowly. It is odd. The thing that most people forget is that in order for you to get back together and compare your clocks, one of you will accelerate. So lets say that he suddenly stops and comes back to you. His clock will seem to have ticked by more slowly than yours because he has moved into your frame of reference. Question two. There is a velocity transformation just as there is a position and time transformation. http://en.wikipedia.org/wiki/Velocity-addition_formula That will probably do a better job of explaining than I will. |
| Dec25-11, 12:58 AM | #3 |
In Newtonian physics velocities are added very simply. If you see person A moving to the right at velocity u and person B moving to the left at velocity v, then the velocity of person A with respect to person B (which we'll call w) is given by: [tex]w=u+v[/tex] In Special Relativity velocities are "added" in a slightly more complex way. The relativistically correct equation is: [tex]w= \frac{u+v}{1+uv/c^2}[/tex] When you use this equation you will always end up with an answer such that w<c. For example, in the problem you give: [tex]w= \frac{u+v}{1+uv/c^2} = \frac{0.75c+0.75c}{1+(0.75c)(0.75c)/c^2} = 0.96c[/tex] So friend 1 is only traveling at 96% the speed of light with respect to friend 2. |
| Dec25-11, 06:57 AM | #4 |
re: QUESTION #1:
re: QUESTION #2: That is so cool. Elfmotat your explanation could not have been more clear, thank you. |
| Dec25-11, 07:42 AM | #5 |
If your friend returns, he must accelerate. He is no longer in an inertial reference frame. Since he has accelerated, he has moved into your reference frame and the view of time that you had been seeing would be the correct one.
If you had instead accelerated in order to catch him (in his view, stopping and turning around) then your time would have been behind. In your example above, indeed his clock would read 6 and yours 7. The absolute difference between your clock and his is not a contradiction of special relativity, because he has not been in a single inertial reference frame the entire time, but you have. |
| Dec26-11, 04:10 PM | #6 |
| Dec26-11, 05:17 PM | #7 |
Time≠motion≠energy. Where do you get these weird ideas from? And it doesn't matter how much energy was used to put you in motion, electrons will cycle the proton exactly the same as they did when you were at the resting state. |
| Dec26-11, 05:19 PM | #8 |
| Dec29-11, 10:39 AM | #9 |
So it seems to me that you're saying that your SPEED relative to mine has no effect on your time relative to mine; rather it is only your ACCELERATION relative to mine that will slow your time down. Is that right? If that's true, then the following two scenarios would also be true, I think: A) If I am floating in space and I saw a clock flying past me at a constant speed of 290,000 km/s relative to me, that clock would not seem to me to be running any slower than my own clock. (since both my clock and the other clock are traveling in a straight line at a constant speed, they are both in the same inertial reference frame, therefore time does not slow down for either one). B) Say I am floating in space and I see a clock flying towards me at a constant speed of 290,000 km/s, and then when the clock gets near to me it has a decelerating force applied to it that slows it down so that it is at rest beside me. If I look at that clock, I will see its time running super fast, right? (if the clock had accelerated relative to me I'd see its time slow down; so I assume that if it decelerates relative to me, I'll see its time speed up). Is my understanding of all of this correct? If not, can you correct any of my misunderstandings? Thank you! |
| Dec29-11, 12:52 PM | #10 |
No, your understanding is not correct. In any inertial reference frame, a stationary clock ticks normally and a moving clock ticks more slowly, the faster it moves, the slower it ticks.
| Dec29-11, 01:35 PM | #11 |
For this scenario I think you can safely ignore the FoR, instead considering that neither observer is accelerating. "So it seems to me that you're saying that your SPEED relative to mine has no effect on your time relative to mine;" That statement can be said as "What I observe doesn't effect/change/impact what you observe." |
| Dec29-11, 04:09 PM | #12 |
Let me try to be more precise when I explain this. First, yes, an inertial reference frame is a frame (could be the inside of a space ship, a box, or a simple x and y axis) that has no forces acting on it.
So lets set the stage... Alice and Bob are siblings living in the middle of space with nothing around them. They could either be moving or perfectly still and they would never know as long as they are not accelerating (this includes changing direction). On Earth it maybe difficult to convince yourself of this since even if you move in a car in a straight line, gravity pulls you and the car shudders a little, but you will definitely feel the difference between almost inertial movement and a sharp turn which is certainly accelerated. Now consider a slightly different situation. Alice is in frame A and Bob is in frame B. The two people (whose frames are defined by their motion) are moving past each other in a straight line and have equal claim to being stationary. As they go past each other Alice appears to see Bob moving near the speed of light from her right to her left side. Bob sees Alice move near the speed of light from his right to his left. Alice will see Bob's clock (which I forgot to mention is displayed in such a way that Alice can see it even though they are traveling near the speed of light) ticking more slowly than hers. Bob's Frame of Reference is also an inertial FoR and so we have to assume that he too would have a right to claim that Alice's clock is ticking more slowly compared to his own. I think you understood this from your first post. Informally we can think of the relativity of time like the fact that both Alice and Bob can claim that the other one is moving from right to left (not the same, but it might help?). Now the question: What happens when they come back together to compare clocks? If Alice and Bob are both moving inertially, they are both right. However, in order for them to get back together and compare time, one of them must accelerate! So lets say Bob decides to turn around and go see Alice. When they get back together Bob's clock will have measured less elapsed time than Alice's and they will both agree on that, but their histories will be different. Bob had to change direction which meant that for some period of time he was NOT in and inertial FoR and his claim to equal treatment under Special Relativity is lost. To sum up. When Alice and Bob are in an inertial FoR (like nitsuj says, they can consider themselves to be motionless), the rules of Special Relativity apply and both observe the other's time to be moving slowly. When one of them turns around to come back and meet the other, that person is in an accelerated FoR for some period of time and the transformations of Special Relativity do not apply. (We are assuming that they don't both turn around and accelerate back toward each other and meet up. They could possibly do this and make both clocks the same, but that would be even more unlikely than two sibling floating around in outer space) Does that make it clear? The key is understanding when the principles of Special Relativity apply and when they don't. |
| New Reply |
| Thread Tools | |
Similar Threads for: Relative Motion Leads To Impossibilities (or so it seems to me... can you help?)
| Relative Motion and Two-Dimensional Motion | Introductory Physics Homework | 5 | ||
| Projectile Motion and Relative Motion Principles | Introductory Physics Homework | 1 | ||
| Question on relative motion and circular motion. | Introductory Physics Homework | 6 | ||
| Addressing Impossibilities in the Standard Cosmological Model | Cosmology | 33 | ||
| Impossibilities of the superstring theory | General Physics | 9 | ||
