Energy for Orbits: 500km Above Earth's Surface
  • Thread starter Thread starter ice
    Energy Orbits
The discussion revolves around calculating the energy required to lift a 1000kg object from the Earth's surface to a height of 500km, and the additional energy needed to place it into orbit at that height. The subject area includes concepts of gravitational potential energy and kinetic energy in the context of orbital mechanics.
  • Mixed
  • Participants explore the calculations for gravitational potential energy and the requirements for achieving orbital velocity. Questions arise regarding the relationship between kinetic and potential energy in orbits, and the correct application of formulas related to orbital mechanics.
Participants are actively engaging with the problem, with some providing insights into the differences between lifting an object and placing it into orbit. There is a recognition of the need to consider both potential and kinetic energy changes, though no consensus has been reached on the specific calculations.
There is mention of a quiz context, which may impose constraints on the methods or assumptions participants are willing to explore. Some participants express uncertainty about their calculations and the underlying principles.
ice
This question came up on a quiz and i got it wrong.
a)how much energy does it take to send a 1000kg object from the surface of the Earth to a height of 500km above the Earth's surface? b) how much energy does it take to put the same object into ORBIT at 500km above the surface of the earth.
For part A, i got -4.5*10^9 Joules, but i don't know if that's right.
part b is what i really don't understand, so any help here would be appreciated, thanks.
In part A you simply calcuated the amount of work required to lift an object to a certain height. If you simply lifted it to that height and let it go it would simply fall back to Earth. In part B, the keyword is ORBIT which means that in addition to merely lifting the object you must impart to it sufficient velocity for it to remain at that height in order for it to ORBIT the Earth. You will find that the kinetic energy requirement of orbiting is substantially greater than the requirement for simply lifting the object.
but isn't Ek=1/2 Ep for all orbits? i tried using v^2 = sqrt(2GM/r), which didnt really work out.
I think for b) it is:
[tex] ME = \frac{1}{2}mv^2 - \frac{mMG}{r}[/tex]
[tex] ME = \frac{mMG}{2r} - \frac{mMG}{r}[/tex]
The Mechanical Energy = Kinetic Energy + Potential Energy
I substituted the orbital velocity for v which equals to:
[tex] v_{orb} = \sqrt{\frac{MG}{r}}[/tex]
You can derive this by putting the Gravitational Force to be equal to the centripetal force.
If there are any errors - feel free to comment.
The part that you're leaving out is that the payload starts off on the surface of the Earth with whatever potential energy it has there and (in the simplified case) NO kinetic energy. What you need to calculate is the CHANGE in both the payload's potential energy and kinetic energy.
16K
