Find area of regions bounded by curve and line
The discussion focuses on finding the area of regions bounded by the circle defined by the equation x² + y² = 9, the line y = 2x, and the x-axis in the first quadrant. The initial attempt involved transforming to polar coordinates with limits 0≤θ≤tan⁻¹(3) and 0≤r≤3, leading to an incorrect final answer of (9/2)tan⁻¹(3). The correct limits for θ should be 0≤θ≤cos⁻¹(1/√5), which corresponds to θ = tan⁻¹(2), resulting in the accurate area calculation of (9/2)tan⁻¹(2).
  • Understanding of polar coordinates and transformations
  • Knowledge of integration techniques in calculus
  • Familiarity with trigonometric functions and their inverses
  • Ability to graph equations and interpret geometric areas
  • Study polar coordinate transformations in calculus
  • Learn integration techniques for calculating areas between curves
  • Explore trigonometric identities and their applications in calculus
  • Practice graphing conic sections and linear equations to visualize bounded areas
Students studying calculus, particularly those focusing on integration and area calculations, as well as educators looking for examples of polar coordinate applications.
DryRun
x^2 + y^2 = 9, y = 2x, x-axis in the first quadrant
The attempt at a solution
So, i drew the graph of y against x in my copybook, and circle with origin (0,0), radius = 3 units. The line y = 2x cuts through the circle.
Transforming to polar coordinates, the new limits are:
0≤θ≤tan^-1(3) and 0≤r≤3
[tex]\int\int rdrd\theta[/tex]
After integration, i get the final answer: (9/2)tan^-1(3)
However, the answer in my notes is: (9/2)tan^-1(2). Did i copy the wrong answer or is my work wrong? I'm not sure.
Your answer is wrong, because the following is wrong
...the new limits are:
0≤θ≤tan^-1(3)...​
OK, so here is the graph:
http://s2.ipicture.ru/uploads/20111227/zpUVSESp.jpg
From my understanding, i need to find the area of the red section from the graph above.
For θ fixed, 0≤θ≤cos^-1(1/√5) and 0≤r≤3
I checked from calculator and cos^-1(1/√5) = tan^-1(2)
Thanks for your help, SammyS.:smile:
  • · Replies 19 ·
  • · Replies 20 ·
