ZPE energy levels and cosmology.
The discussion revolves around the implications of zero-point energy (ZPE) in the context of cosmology, particularly its relationship with gravitational effects and the reconciliation of quantum theory with general relativity (GR). Participants explore theoretical models, predictions, and potential experimental validations related to ZPE and its influence on cosmic phenomena.
  • Experimental/applied
  • Some participants discuss the implications of the Heisenberg uncertainty principle on the energy levels of the ZPE field, suggesting that higher energy levels could lead to gravitational collapse, which has not occurred.
  • One participant proposes that the effective ZPE is limited by the curvature of space-time, potentially acting as a form of dark energy with a specific density.
  • Another participant mentions that the theory predicts a detectable 'bottoming out' of the Casimir force in the solar gravitational field, particularly around the orbit of Jupiter.
  • There is a suggestion that the Pioneer anomaly may not be directly related to ZPE but could involve a time slip between atomic clock time and ephemeris time, alongside other factors.
  • One participant questions why curvature would limit ZPE, proposing that the presence of mass increases ZPE above dark energy density and discussing the role of gravitons in this context.
  • Another participant elaborates on the density of ZPE being proportional to distance and suggests that the Casimir force may not be detectable in the absence of gravitational fields, while still being measurable under certain conditions.
  • There is a proposal that ZPE fields could be polarized in the presence of matter, affecting gravitational interactions and inertia, and that experiments could measure variations in the Casimir force due to ZPE field gradients caused by celestial bodies.
Participants express differing views on the relationship between ZPE, curvature of space-time, and gravitational effects. There is no consensus on the mechanisms at play or the implications of the theories discussed, indicating an ongoing debate.
Participants reference specific theoretical frameworks, such as SCC, and discuss various assumptions regarding the nature of ZPE and its interactions with mass. The discussion includes unresolved mathematical aspects and dependencies on definitions related to ZPE and gravitational effects.
turbo
Insights Author
In a post below relating to Hawking radiation, Chronos linked to a page that expressed the existence of virtual pairs as a product of energy and time limited by the Heisenbug uncertainty principle:
[tex]\Delta E\Delta t\geq\frac{\hbar}{2}[/tex]
This simplified view neatly illustrates one of the problems facing the folks who are attempting to reconcile quantum theory with GR. If we model the ZPE field using shorter and shorter time intervals, the permissable energies get higher and higher, leading us to the conclusion that the total energy of the ZPE field is immense. In the GR view of mass/energy equivalence, this energy would cause our universe to collapse to a volume not much larger than the Earth. Clearly, this has not happened. The quantum model of the vacuum is greatly at odds with GR.
What limits the gravitational effect of the ZPE field?
Astronomy news on Phys.org
This ‘ultra-violet catastrophe’ is a problem for the standard theory, however one possible answer to this question is that in the theory of SCC (pages 11,12) the effective ZPE is limited by the curvature of space-time. Therefore the gravitational effects of the effective ZPE would be also limited and can be thought of as a form of 'Dark Energy', though with a total density of only 0.11 critical density.
In the theory there are two separate solutions to the scalar field equation, one derived from Mach's Principle, and the other derived from the local conservation of energy. These solutions converge as space-time tends to asymptotic flatness but diverge as curvature increases. Consistency between these two solutions requires a small amount of vacuum energy density, consistent with observations of the Casimir energy field, that is a function of the curvature. One prediction of the theory is that there should be a 'bottoming out' of the Casimir force that should be detectable with present sensitivities in the solar gravitational field at around the orbit of Jupiter (and well away from the planet's own field).
Garth
Garth
Does this bear upon SCC's treatment of the Pioneer anomaly?
Not directly - there is also a time slip in SCC between atomic clock time and ephemeris time which would explain the Pioneer anomaly, at least to within an OOM. The anomaly may be due to a combination of several effects, gas leakage, anisotropic radiation budget etc. more investigation is required to tie the effect down.
Garth
Garth:
Rothie M:
Why would curvature limit ZPE?
When masses are put in the vacuum ZPE increases above dark energy density-
Casimir force!
However,if the ZPE consists of gravitational force carriers perhaps they would
not curve space-time i.e gravitons might not be absorbed and emitted by gravitons
whereas gravitons would be emitted and absorbed by protons,electrons etc.
Garth's SCC paper said:
This density is proportional to r−4 and limits the maximum Casimir force that might be detected. This limit may be detectable at a sufficient distance from gravitational masses. Thus the theory implies that in at space-time, in the absence of gravitational fields, the Casimir force would not be detectable at all! The theory does suggest that an experiment launched away from the sun, which compared the Casimir force against separation, would detect the force rounding off as the limit to the Casimir effect was reached. This limit may be detected at around 5 A.U. with current experimental sensitivity.
I read this a few months ago, when we discussed availability of experiments to test non-standard cosmologies, and I'd love to see such an experiment. In my model, the ZPE fields are densified/polarized in the presence of matter and interaction of masses with the polarized fields is the cause of gravitation and inertia. I predict that in "empty" space (in the absence of large nearby masses), the ZPE fields would be relaxed and unpolarized, but that the Casimir force would still be measurable. After all, the ZPE fields exist in empty space and they exert pressure, so exclusion of some frequencies of these particle pairs in a Casimir device should still create a field somewhat below the ZPE ground state and result in an apparent attraction of the plates. If the ZPE fields are polarized by mass, an orbiting Casimir detector should be able to measure differences in the Casimir force due to ZPE field gradients caused by the Earth, the Moon, and the Sun. Of course, I would dearly love to see such an experiment performed.
Rothiemurchus said:
Garth:
Rothie M:
Why would curvature limit ZPE?.
Rothie M - This effect is a feature of SCC not GR. I gave the SCC 'hand waving' explanation in post#2 above, for the mathematics you might like to follow the link to SCC in that post.
Casimir force!
In SCC the ZPE consists of virtual particles with either energy or energy equivalent rest masses, photons, electrons, positrons etc.
Garth
  • · Replies 29 ·
  • · Replies 153 ·
14K
  • · Replies 62 ·
13K
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 30 ·
