Relativistic mass thought experiment/proof?
The discussion revolves around the concept of relativistic mass in the context of special relativity. Participants explore whether there is a straightforward proof for relativistic mass similar to those for length contraction and time dilation. The conversation touches on the relationship between relativistic mass, invariant mass, and the momentum four-vector.
  • One participant expresses confusion about the lack of clear explanations for relativistic mass compared to other concepts in special relativity.
  • Another participant argues that the concept of relativistic mass is deprecated and that modern physics prefers the term "invariant mass."
  • A participant suggests that the relationship between relativistic mass and invariant mass can be expressed using the momentum four-vector.
  • There is a discussion about using a right-angled triangle to visualize the relationship between energy and mass, with some participants questioning the validity of this approach.
  • One participant attempts to derive expressions related to relativistic mass but acknowledges confusion and seeks clarification on their derivation.
  • Another participant offers a suggestion to start with a specific function to derive relativistic mass without involving energy concepts.
  • There are multiple references to external resources for further reading on the topic.
Participants do not reach a consensus on the validity or utility of the concept of relativistic mass. Some advocate for its use, while others argue against it, leading to a contested discussion.
Participants express varying levels of familiarity with mathematical concepts, which may affect their ability to engage with the topic. Some discussions involve assumptions about prior knowledge of calculus and four-vectors.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring special relativity and the concepts of mass and energy.
sorax123
Hey all,
After reading some fairly elementary texts on special relativity, I understand length contraction and time dilation no problem, as it is well explained with examples of proofs, but I hate to say that relativistic mass is explained nowhere. I know this question has probably been asked before, but I will ask it anyway: Is there a fairly simple proof for relativistic mass, just as there is for length contraction and time dilation? Is it something to do with spacetime momentum four vector or something along those lines? I would really love to understand this, as it would allow me to understand special relativity more fully in order to read about general realtivity etc.
Any answer would be gratefully appreciated.
Thanks, Dom
sorax123, In relativity the three-momentum is p = γmv where m is the rest mass. In olden times people tried to make this look like Newtonian mechanics by defining a relativistic mass M = γm, just so they could write it as p = Mv. Bad idea. It is not the actual mass and leads to a great deal of confusion. Suggest you avoid it like the plague.
I second Bill_K's suggestion. Relativistic mass is a generally deprecated concept. When modern physicists speak of "mass" they almost exclusively mean "invariant mass".
Thanks for your additions guys, but for my piece of mind, is there any way to prove it, as it must have some weight behind it? I see some people use a right angled triangle with the hypotenuse being E=mc^2, and the other two being Ep=pc=mvc and Eo=moc^2, but how is this the case as where i have read the hypotenuse is mc, being the vector of the momentum four vector, the time part being γmc, and the space part being γmv, so how can this be?
Any help to regain my sanity would be appreciated.
D
Are you familiar with four-vectors?
I am familiar with the momentum four vector, so I suppose I am :/
Then we have: [itex]\mathbf p = (E/c,p_x,p_y,p_z)[/itex]
The invariant mass is then defined as: [itex]- c^2 m_{invariant}^2 = |\mathbf p|^2= -E^2/c^2 + p_x^2+p_y^2+p_z^2[/itex]
The relativistic mass is defined as: [itex]m_{relativistic} = E/c^2[/itex]
For a timelike particle we have [itex]p_i=m_{relativistic} v_i[/itex]
So by substitution and solving you can obtain:
[tex]m_{relativistic} = \frac{m_{invariant}}{\sqrt{1-v_x^2/c^2-v_y^2/c^2-v_z^2/c^2}}=\gamma m_{invariant}[/tex]
I kind of get what you're saying in your reply, but I was wondering if there was a different way of getting it. The idea of the right angled triangle with the sides mentioned in my original post seems the most simple, so is there any way you could explain that?
My brain says thanks
Well, (setting c=1 for convenience), from the above, you can always write:
[itex]m_{relativistic}^2=m_{invariant}^2+p_x^2+p_y^2+p_z^2[/itex]
which is the equation for the hypotenuse of a 4D "triangle". However, note that the space in which this "triangle" is NOT the usual Minkowski spacetime. The invariant mass is the "hypotenuse" of that "triangle".
Aha I see, this seems to make sense more
But still, out of curiosity, how on Earth could you derive the expressions displayed in post 1? :S
Thanks for your reply Dr, I am only a high school student, and haven;'t covered calculus :/, was wondering if there was a more elementary derivation?
There are no expressions displayed in post 1:
sorax123 said:
Hey all,
Thanks, Dom
Perhaps you meant to include something, but forgot.
Apologies for that, stupid mistake on my behalf; I meant my second post regarding the right angled triangle :)
That should be sufficient if you start with m(v):=mo·f(v) and forget about the energy.
I originally tried to prove it as follows, but works only if time dilation is used, without length contraction, when length contraction is introduced the mass is deemed to be more;
γmL/T=γm'L'/T'
γmL/T=m'L/γT
multiplying both sides by T gets us:
γmL=m'L/γ
multiplying by γ gets:
γ2mL=m'L
so:
m'=γ2m
I know there is something wrong here as is should be m'=γm, please correct my arithmetic, or let me know if it is possible to show relativistic mass in this form.
Just take the second equation in my post 7, multiply both sides by c², and then substitute in the third equation.
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 28 ·
  • · Replies 143 ·
10K
  • · Replies 61 ·
  • · Replies 17 ·
