How would you test large vehicle for sinusoidal vibration
The discussion revolves around methods for performing sinusoidal vibration tests on large vehicles, specifically those weighing over 40 tons. Participants explore the feasibility of testing equipment and techniques used in such evaluations.
  • One participant inquires about the testing methods for sinusoidal vibration on large vehicles, expressing confusion over the lack of powerful testing devices.
  • Another participant suggests that there are vibration test facilities for large vehicles and questions which specific vehicle the data pertains to, proposing that manufacturers may have their own testing facilities or contract with specialized test houses.
  • A different participant mentions the availability of hydraulic actuators capable of applying significant force at high frequencies, indicating that such devices can be sufficient for vibration testing without needing to match the vehicle's weight directly.
  • One participant notes that a static load test can provide insights into the structural limits of vehicles, using aircraft wings as an example.
Participants express varying levels of understanding and approaches to the testing methods, with no consensus reached on the best practices for conducting sinusoidal vibration tests on large vehicles.
Some assumptions about the capabilities and limitations of available testing equipment remain unaddressed, and the discussion does not resolve the specifics of the testing methodologies or the adequacy of the proposed solutions.
Individuals interested in vehicle testing, vibration analysis, engineering practices, or those involved in the design and testing of large vehicles may find this discussion relevant.
nortel
Hey, could anyone explain how you would preform a sinusoidal test on large vehicle (weight>40 tons). I have a graph from sinusoidal data, but i don't understant how they were able to obtain this information because there is not a powerful enough testing device.
How much does a Boeing 747 aircraft weigh?
http://www.worldwide-aviation.net/index.php?option=com_content&view=article&id=164:delayed-747-8-set-for-pre-flight-shake-tests&catid=39:ac-manufacturers&Itemid=68
There are some vibration test facilities for large/heavy vehicles. What vehicle do you have data on? Perhaps that manufacturer has a large test facility including a vibration test area, or else contracts out to some large test house?
EDIT -- A Boeing 747 weighs more than 40 tons:
http://www.boeing.com/commercial/747family/pf/pf_facts.html
You can buy hydraulic actuators that will apply 10 or 20 tonnes force at frequencies up to 100 or 200 Hz "off the shelf". That's more than enough for most vibration testing. You don't need to apply a 40-tonne force to shake a 40-tonne structure by a measurable amount.
This is a static load test not a vibration measurement, but it give an idea what sort of test rigs are built for special purposes: (It also show how much aircraft wings can bend before they break, which might be a surprise!)
Thanks for the examples and the help, It makes sense to me now.
  • · Replies 0 ·
10K
  • · Replies 27 ·
  • · Replies 16 ·
