A basic ODE where Runge Kutta doesn't work?
  • Context: Graduate
  • Thread starter Thread starter h1a8
    Ode Runge kutta Work
The discussion revolves around a specific ordinary differential equation (ODE) derived from a cubic function, focusing on the behavior of various Runge Kutta methods when applied to this equation. Participants explore the discrepancies between expected real solutions and the complex results produced by computational software.
  • One participant presents a separable differential equation and notes that computational methods yield complex solutions for y(1), despite the expectation of real values.
  • Another participant suggests that the presence of negative numbers in the root leads to complex results, as the software defaults to the principal root for negative inputs.
  • A different approach is proposed, where the argument to the power (1/3) is made non-negative by squaring the term before applying the root, which is claimed to align with the intended outcome.
  • Participants discuss the implications of fractional powers of negative numbers and how they can lead to unexpected results in computations.
  • One participant expresses surprise at the software's handling of complex roots, indicating a lack of awareness regarding the default behavior of these programs.
Participants generally agree on the issues arising from the handling of negative numbers in the context of fractional powers, but there is no consensus on the best approach to resolve the discrepancies in the computational results.
There are limitations regarding the assumptions made about the behavior of fractional powers and the definitions used in the context of the ODE. The discussion highlights unresolved mathematical steps related to the application of the Runge Kutta methods.
h1a8
From a cubic function where y(0)=1, y(1)=0, and where there is a local max at y(5/13) I created a basic separable differential equation problem. I wanted to analyze how well different ordered Runge Kutta methods works in an interval [0,1]. Here it is:
dy/dt=-6(6/13)1/3(y-343/468)2/3 , y(0)=1
This ODE yields the cubic solution of
y=1/468(-12t+5)3+343/468
Now it is clear that y(1)=0
But using the several Runge Kutta programs with various computer software (mathematica, ti-nspire cas, mathstudio, etc.) yields a complex solutions for y(1). For example, using the classical RK4 with h=.1 yields
y(1)=0.718779+.005811i.
I don't see how the programs get a complex solution when all the functions have no even roots. Does anyone what is going on with these programs?
You have negative numbers in that root for y<343/468. All of the mentioned programs are won't to go to complex numbers ASAP. Those programs will take the principal root. For example, the principal root of (-1)2/3 is (-1+i√3)/2, not 1.
Yep.
Try dy/dt=-6 (6/13)1/3 ((y-343/468)(y-343/468))1/3 instead.
By multiplying (y-343/468) with itself first, you make sure that the argument to the power (1/3) is non-negative.
This way it will do what you intended.
I like Serena said:
Yep.
Thanks that works. I tried ((y-343/468)2)1/3 and that works too.
Didn't know the programs calculated the principle cube root of negatives by default even if they were complex.
Well, basically they don't have a choice.
What do you think (-1)^0.667 is?
Nice trick.
h1a8, this works because of the identity (ab)c=abc.
This identity is valid if a is positive and b and c are real. It is not valid in general. (The same goes with a lot of other exponentiation identities.)
  • · Replies 65 ·
10K
  • · Replies 31 ·
